Author Topic: Manual gearbox fitments  (Read 2914 times)
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: Manual gearbox fitments
« Reply #15 on: 22 April 2011, 11:00:42 »
I have been told DMF were fitted to Omagas, I am not a fan, they seem pointless to me. I had a single mass fitted to my wifes TDCi Mondeo and I cant notice any difference.
Also they are heavier I think. I do fancy a lighter one but not sure I can warrant £250 odd for a lightened one.
You will aslo have to factor in the price of a clutch plate with a sprung hub, the Omegas don`t have these as the driveline damping is taken care of by the DMF.
I think TTV have made one for an Omega before so suit the standard pressure plate and then you could use the friction disc from a 20LET, it`s slightly smaller in diameter but would easily cope with the torque of the 3.0l.
I had one from them for my Senator and there`s a few people on the ABS forum using them in Monza`s.
mdbs
« Reply #16 on: 22 April 2011, 15:12:29 »
OK, thanks. I will not be tuning the engine though. AS I have not done anything like this for a while I am sort of using it to get back up to speed.
My next project, it was due to be this one but the MX turned up, is a Se7en type with a BMW 4.0 V8 manual.
But I am not holding my breath.
mdbs
« Reply #17 on: 22 April 2011, 15:19:22 »
There are loads of manuals on Ebay, thanks. Its agood idea anyway to have some reference for the engine/box etc.
Am I correct that the MV6 has an LSD? Not sure if the MX diff will cope so might keep the Omega diff handy.
2woody
  • Northumberland
« Reply #18 on: 28 April 2011, 15:51:27 »
also, do remember that whatever you transplant into an MX-5 shell, you must, must, must, must, must re-use the torque arm that connects the diff to the gearbox. The shell isn't designed to take torque reaction and som will end up corkscrew-shaped if you don't tie the two together.
mdbs
« Reply #19 on: 28 April 2011, 20:00:05 »
I wondered why they did it that way, thats a good bit of info, and to be honest I was going to re use it anyway thinking it wasnt there for nothing.
Thanks
