Author Topic: Torque convertor possibly  (Read 1409 times)
mantahatch
« on: 27 April 2011, 20:01:10 »
Think I may have made a mistake. Fitted an AR35 box to mums 2.5CDX using the 2.5 torque convertor. It seemed to fit very nicely. I did spill a little oil in the bell housing while fitting it.
There was no immediate leak but 4 day later a spot on the drive about 2 inches accross. Put that down to what may have been in the bellhousing. anyway no more leaks till today when a patch about 10 inches in diameter appears.
Has anyone any idea what I have done wrong please.
Many Thanks
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Torque convertor possibly
« Reply #1 on: 27 April 2011, 23:34:16 »
did you fit the g/box with the converter as a complete item or was the converter left on the engine,if the latter its really easy to damage the seals when trying to fit the box
other rides
mantahatch
« Reply #2 on: 28 April 2011, 07:36:03 »
TC was removed with auto box. box was then stood on end and carefully lifted TC off.
Putting TC back on I was careful but it did no sit down properly until I rotated it and it the dropped about 1/2 an inch to sit properly.
I assume I am going to have to take it all out again, ho hum such is life.
Many Thanks
« Reply #3 on: 28 April 2011, 10:13:56 »
Sounds like you followed the correct procedure but it's always possible that the gearbox wasn't removed from the previous car with as much care.  :(
The oil seal at the front of the gearbox can be changed easily enough. While you're there I would check for scoring on the torque converter nose and see if you can look into the gearbox and see damage on the bush that this locates into though.
mantahatch
« Reply #4 on: 28 April 2011, 12:01:36 »
Thanks Kevin. It was purchased off the forum from someone whom I believe to be very trustworthy and don't believe he would have removed it incorrectly.
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #5 on: 28 April 2011, 12:15:43 »
It might just need a new seal,  if it was mine i would have fitted a new seal before fitting but that is just me being super safe. But it does sound the the box will have to come out again. ::)
Jaguar XJ6
« Reply #6 on: 28 April 2011, 12:25:02 »
I assume the leak is from inside the bellhousing?
mantahatch
« Reply #7 on: 28 April 2011, 13:44:27 »
Not actually been under for a close examination but looking from the side and front it seems to be around the bellhousing area, and front autobox sump. but that could just be blown back in the wind.
At least it is a fairly simple job to take it out again.
Thanks Chaps.
« Reply #8 on: 28 April 2011, 13:53:16 »
Worth a check for the easy things first.. Cooler pipes leaking? Breather pipe come loose or dropped down from behind the engine? Sump gaskets? Another seal on the auto box leaking, etc...
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #9 on: 28 April 2011, 22:55:13 »
Thanks Chaps.
Is it easy enough to remove?
mantahatch
« Reply #10 on: 29 April 2011, 09:28:24 »
Will do. Thank you.
mantahatch
« Reply #11 on: 29 April 2011, 09:34:11 »
Thanks Chaps.
Yes it is. took me 4 hours to change box with 70 year old passing me spanners etc and 17 year old being shown what to do, and using his young muscles to undo some of the stubborn bolts. And that was on 4 car ramps.
I will add that tme did not nclude a flud change. The idea being to run it as is for a couple of weeks to check it was ok then do a flud change. I am somewhat glad that is what we decided on, as to see ne flud all over the ground would be somewhat disheartening.
