Author Topic: Oh dear! Oil Leak...  (Read 4096 times)
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
« on: 22 April 2011, 19:34:07 »
Hi Lads.  Here's another old oil leak chestnut!  New cam covers fitted and gaskets done properly but the oil still leaks from somewhere.  :'(  What is around the back of the engine that can still leak?  :(   Could the head be cracked?  :o
Its the right hand bank of a 2000 xreg 2.5 petrol with 124.000 miles on the clock.  The repair bill so far is about £800.....and still dripping.  :'(    Any idea's? :-/
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Re: Oh dear! Oil Leak...
« Reply #1 on: 22 April 2011, 19:42:08 »
....  New cam covers fitted and gaskets done properly but the oil still leaks from somewhere.  :'(  ........
OE gaskets?  :-/ Who fitted them? Could they have caught the D part of the gasket at the back & it's not sitting correctly.
'Right hand bank' as you're sat in the car or looking at it from the front? Right is technically the (UK) driver's side & is the easiest to fit due to being less crap stuff in the way.
SJKOO01
« Reply #2 on: 22 April 2011, 19:43:35 »
Take it that genuine gaskets have been used and not automotive shop copies.  Can you see if the half moon part of the gasket is sitting correctly in place, as if it's come slightly adrift when putting back it could be leaking from there.
If you don't feel confident in where you've had the work done (if at a garage), then try pm'ing one of the mechanic's on here who maybe able to help you out.  There'll be cheaper and do a better job at getting it right first time  :y
Darth Loo-Knee (Stoke)
Elite Pete (Chester way)
Wellung (West Mid's) - though will have to pm me so I can pass on his contact number to you, as not able to get on here at moment, due to computer access issues  ::) .
Or there maybe someone closer to you who maybe able to help you out.
« Last Edit: 22 April 2011, 19:44:02 by SJKOO01 »
Bixy1
    • Cats Tails
« Reply #3 on: 22 April 2011, 19:45:26 »
Hi Andy!   Front looking back, passenger side.  He's an ex-Vauxhall bod, been doing these for a while.  :-/
Bixy1
    • Cats Tails
« Reply #4 on: 22 April 2011, 19:47:35 »
Ta GooseMan.  Yes, proper gaskets used. New camcovers £84 each...  :o
SJKOO01
« Reply #5 on: 22 April 2011, 19:52:42 »
Not being funny here or anything.  But is he a mate of yours or someone at a local garage you know?
As if you've been charged £800 so far and there's still no cure I'd be suspicious that you're being ripped off  :-?.  Sorry but that's how I see it.  ::).
Is there anyone else you know that could check down the plug wells to see if there is oil collecting down there, if there is, it may well be the gaskets not sitting right.  Take it the cam covers were new and you were advised to get them replacd?
« Last Edit: 22 April 2011, 19:55:37 by SJKOO01 »
« Reply #6 on: 22 April 2011, 19:56:26 »
Agreed. £800 is a staggering amount of money to be charged for repairs.I would expect a whole recon engine to be fitted for that. :o
WGoins88
  • Amherst, Ohio, USA
« Reply #7 on: 22 April 2011, 20:00:50 »
There is also the possibility of the oil cooler lines coming loose at the cooler if they weren't tightened down properly, or they could have chafed somewhere and made a pinhole. Remember, even the smallest oil leak can make a HUGE mess.
Just throwing out some possibilities....I could be very wrong.
1997 Catera - 75k miles
Vplatform.forumer.com
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #8 on: 22 April 2011, 20:04:22 »
Have the breathers been cleaned out properly?
TuBy's new whipping boy.
Bixy1
    • Cats Tails
« Reply #9 on: 22 April 2011, 20:11:16 »
Oh sorry, £800 includes new timing belt, tensioner, water pump etc and complete breather clean, not forgetting good old VAT.  :o  I'ts a long tedious story....and its really getting on my wick now. My fault for buying such a dog... :-[
Not a mate, but I trust him.  I've seen the old camcovers. Warped to chuff and one of the mounting bolts stripped out. Had to be re-tapped.
Do the oil cooler pipes go around the back of the engine then?  :-?
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #10 on: 22 April 2011, 20:43:26 »
That's right - there are 2 metal oil pipes running from the oil cooler around and down the back of the passenger side head, and fitting into the side of the block above the oil filter.
It's either those pipes and their fittings, or the cam cover gaskets.
Omega 2.5 V6 Facelift Estate.
Bixy1
    • Cats Tails
« Reply #11 on: 22 April 2011, 22:03:44 »
Cheers1 I'll ask him to check that out.  :y
« Reply #12 on: 23 April 2011, 10:09:28 »
Thats still £400 to much ::)
ChrisWallMV6
  • Chesterfield
« Reply #13 on: 23 April 2011, 15:15:02 »
Had your crank seal checked? Oil filter nice and tight?
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
« Reply #14 on: 23 April 2011, 15:25:14 »
i had this problem with a 99 elite,did cam cover gaskets gen vx ones,still leaked oil,turned out to be head gasket on the same side as yours,theres an oil way right at the back corner an it started leaking out the way,so head off did gasket an never had any probs after that,just worth mentioning i thought
