Author Topic: Towbar recommendations  (Read 3827 times)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« on: 27 April 2011, 23:07:09 »
Greetings! Can anyone recommend a good towbar for my facelift saloon please? I've got a factory fit detachable one on the MV6 but need one for the elite. Ideally a flange type one, ideally with twin electrics for my caravan. Also, what's a bypass relay, what does that do? Thanks
P.S. I've seen witter ones and heard they're meant to be quite good? How much should i be paying for one? I'll fit it myself, I know they're meant to be type approved and all that.
Thanks peeps
TC and BnQ Trade holder.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Towbar recommendations
« Reply #1 on: 27 April 2011, 23:16:58 »
the bypass relay eliminates any extra load on the vehicle lighting circuit,basically a fancy switching relay  which you wire in with its own live to power the trailer lights,if its just a trailer board being used its not important to use one but modern caravans have lots of lights so quite a good idea to fit one.I wired the t/bar on my mig using one and it has the indicator audible warning built in :y
« Last Edit: 27 April 2011, 23:18:01 by henryd123 »
other rides
geoffr70
  • Sunderland
  • Boobies
« Reply #2 on: 27 April 2011, 23:21:21 »
My caravan is a fifty million year old shed on wheels, it's only got the normal lights at the back, could i just get a normal twin electrics towbar, one for the lights and the other to power the fridge to keep my bombardier cold on the way to the campsite? Thanks :y
henryd
  • west cornwall
« Reply #3 on: 27 April 2011, 23:28:37 »
The main reason I fitted one to my elite was because of the brake light check circuit,I thought that it might break that up with the van attached
other rides
geoffr70
  • Sunderland
  • Boobies
« Reply #4 on: 27 April 2011, 23:32:06 »
oh yeah, didn't think of that! Thanks
« Reply #5 on: 27 April 2011, 23:33:49 »
An Omega has pretty basic electrics for the trailer lighting so you don't need a by-pass relay. If you get a proper 'trailer check control' relay from Vauxhall (mine was c£16) then you get brake light check on your trailer/caravan too.  :y :y
geoffr70
  • Sunderland
  • Boobies
« Reply #6 on: 27 April 2011, 23:37:30 »
Thanks AndyB
geoffr70
  • Sunderland
  • Boobies
« Reply #7 on: 27 April 2011, 23:38:21 »
I've seen so many different shapes of towbar when I search for them on egay, does anyone know which one is best? Thanks
henryd
  • west cornwall
« Reply #8 on: 27 April 2011, 23:46:14 »
depends if you want swan neck or flange type,I went for brink detachable as I used to get fed up bashing my shins on the fixed flange type that I had on my previous jeep when loading gear into the boot
other rides
geoffr70
  • Sunderland
  • Boobies
« Reply #9 on: 27 April 2011, 23:50:36 »
can the swan neck be quickly and easily removed (just the back bit) as if to make on there is no towbar? And can it also be installed without bumper cut and removal? Thanks
henryd
  • west cornwall
« Reply #10 on: 28 April 2011, 00:05:07 »
the brink that I used does need a bumper cut but its not visible from behind,its very neat and tidy and there is a knob which you push in and turn to remove the bar(which is lockable with a key)
this is the saloon version of the bar that I have   http://cgi.ebay.co.uk/Brink-Detach-Towbar-Vauxhall-Omega-Saloon-94-03-/230598437749?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b0bceb75#ht_2821wt_1139
other rides
geoffr70
  • Sunderland
  • Boobies
« Reply #11 on: 28 April 2011, 00:10:34 »
Thanks Henry, if I've done my abs ecu and exhaust manifold could I fit that? Is the electrics easy enough? Don't know much about electrics me. Thanks
henryd
  • west cornwall
« Reply #12 on: 28 April 2011, 00:32:57 »
Don't know about the saloon but the estate was easy to fit,the underside of chassis is pre-drilled and the boot floor is dimpled where you need to drill and open the holes for the spacers to fit,i believe that the fitting instructions are in that link that I posted :y
As for the electrics you have your other mig for a pattern
« Last Edit: 28 April 2011, 00:34:19 by henryd123 »
other rides
Martin_1962
« Reply #13 on: 28 April 2011, 11:21:34 »
I got a Towtrust one off Ebay (I think) about 5 1/2 years ago.
Seems fine.
I did convert the caravan and car to 13pin last year - consider it seriously - seems better sealed and better connected.
GrahamK
  • Shropshire
  • 2003 2.6 CDX Saloon
« Reply #14 on: 28 April 2011, 11:28:51 »
Hi,
I was in the same position until last week. Got a quote from a good company local to me for £209 fitted for a twin electrics G67A witter towbar. (too expensive for me)
Last one was around half that but as it was for an older car, it didn't need to be type approved, my new 2002 mig of course does. I looked on ebay and the same towbar was on B-I-N for £50. £9.50 postage using payperparcel from Scotland- not bad. They are out there.
I will be fitting a auto switching split charge relay to use with our caravan, so power is only delivered to the leisure battery and caravan fridge when the alternator is charging.
Some thing like this :-
http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1311&_nkw=split+charge+relay&_sacat=See-All-Categories
Hadn't thought about the bypass relay, but perhaps one with the winker buzzer integrated might be a good idea.
Regards,
Graham.
