Author Topic: Wanted ASAP  (Read 2484 times)
Nathan
  • Northwood
  • Just Getting Amongst It
Wanted ASAP
« on: 29 April 2011, 15:34:39 »
Locking wheel key for my Elite as pictured below
Thanks Nathan
Irmscher Parts Wanted...........Vehicle detailing is my passion not just a hobby....
Re: Wanted ASAP
« Reply #1 on: 29 April 2011, 15:58:03 »
try to get the spinning collar off with a very slim chisel/screwdriver & try these ...... http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_196491_langId_-1_categoryId_165469
Failing that, my local ATS had set of them & removed mine for me after a Kwik Fit fitter monkey broke my key.  :y
Nathan
  • Northwood
Re: Wanted ASAP
« Reply #2 on: 29 April 2011, 16:32:10 »
Thanks Andy... may have to do that if i cant locate a spare key :y
Nathan
  • Northwood
Re: Wanted ASAP
« Reply #3 on: 29 April 2011, 19:12:55 »
If anyone does have one lying around PM me and we can sort out payment etc  :y
Re: Wanted ASAP
« Reply #4 on: 29 April 2011, 19:23:24 »
They are supposed to be different you know, it'd defeat the object if they were all the same  ;)
Nathan
  • Northwood
Re: Wanted ASAP
« Reply #5 on: 29 April 2011, 19:28:40 »
Not so sure on that one as i borrowed my neighbours one from his Vectra and it fitted like a glove........ only he wanted it back >:(
Re: Wanted ASAP
« Reply #6 on: 29 April 2011, 19:32:31 »
The cover plate on my Senator wheels shared the same key as my brother-in-law's Nova wheels, but they are coded hence different keys ......... in the same way as there's going to be another door/ignition key as yours & mine somewhere about. There can only be some many combinations.
Also, by the time they've had a windy gun tightening the bolts to mega ftlbs that'll also affect the fit.
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Wanted ASAP
« Reply #7 on: 29 April 2011, 23:18:15 »
Re: Wanted ASAP
« Reply #8 on: 29 April 2011, 23:20:34 »
have a look at this nathan
http://cgi.ebay.co.uk/Vauxhall-ALLOY-WHEEL-CAP-LOCKING-BOLT-SET-LOCK-NEW-/190405634871?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c550f6b37
looks like you get the nuts aswell  :y
Wrong key/bolts Fiendish one  ;) OP wants wheel bolt key, your link is for the cover over the bolts of some wheel styles.  :y :y
fiend61
  • york
  • each to their own
Re: Wanted ASAP
« Reply #9 on: 29 April 2011, 23:24:58 »
Wrong key/bolts Fiendish one  OP wants wheel bolt key, your link is for the cover over the bolts of some wheel styles
ooerr  so it is  :-[ :-[
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
Re: Wanted ASAP
« Reply #10 on: 30 April 2011, 01:01:14 »
I Removed mine (same as yours) after a lost key, using the chisel and lump hammer method.
either 16 or 17mm multipoint socket, knocked on after shroud is removed.
dead easy, all 4 done in 30mins or less.
Alternatively, if not chisel is available, i found that just knocking the socket on anyway first will help remove or at least loosen the shroud, and then it can be more easily tapped off.
