Author Topic: tapping on start-up  (Read 1106 times)
DOCTORWHO
tapping on start-up
« on: 29 April 2011, 22:18:07 »
hi,all
had my 2.6 for about 6 months now,,,no probs at all,,
about 2 weeks ago,,when starting engine for first time in mornings,,,theres a very slight knocking/tapping noise from engine,,,,
If left to tick over,you cant hear it,,,its only when you press tha accelerator lightly that it starts,,,,
if left to tick-over for about a minute,,it stays quiet,,and is ok for rest of the day,,,theres no power loss at all,,and drives a1,,,,,,,changed the oil and oil filter last week,,,little bit better but still there,,,theres about 65,000 miles on clock,,,belt was done at 43,000 miles,,,,,,,as i say,theres no problem,,,any ideas,???,,,using 10/40 semi,,,,,,someone suggested using 5/30 oil  ???
thanks
Colin
Re: tapping on start-up
« Reply #1 on: 29 April 2011, 22:19:45 »
I would tend to do some quick oil changes, if that doesn't help, use some Wynns lifter treatment.
« Reply #2 on: 29 April 2011, 22:20:40 »
Wynns lifter trearment.
« Reply #3 on: 29 April 2011, 22:21:15 »
Is it a light tap? Could be exhaust manifold ;) ;)
« Reply #4 on: 29 April 2011, 22:33:16 »
2.6 tends to have a very reliable manifold gasket...  ...unlike the poor ones GM fitted to ours ;D
« Reply #5 on: 29 April 2011, 22:55:51 »
Nothing wrong with mine... After it's been run for a few minutes ::) ::) :D :D
« Reply #6 on: 30 April 2011, 09:47:24 »
When you eventually fix it, use the MLS one, not the original.
