Pages: [1] 2 3  All   Go Down
Author Topic: Change broken radiator?  (Read 4827 times)
fcc-pt
  • Portugal
    • Omega B Caravan MV6 3.0
« on: 29 April 2011, 22:58:15 »
Omega B Caravan MV6 3.0 - Radiator Replacing Operation
Hi all, I wonder if someone can help me on this one. I need to change my old radiator from my 1998 omega which has the incoming plastic tube completely broken. Anyway, my main worries are the speed box cooling tubes attached to the old radiator and the aircon...
Should I prepare some kind of plug to seal the oil tubes?
Will I have to refill the gearbox level after replacement?
Is there any chance of gearbox damage when replacing the radiator?
What about the aircon radiator, is there any particular care?
Help needed...
Re: Change broken radiator?
« Reply #1 on: 29 April 2011, 23:02:40 »
Should I prepare some kind of plug to seal the oil tubes? Yep
Will I have to refill the gearbox level after replacement? Nope
Is there any chance of gearbox damage when replacing the radiator? Nope
What about the aircon radiator, is there any particular care? Yep
Help needed...
Oil cooler pipes.......you`ll only lose a slight amount......when disconnected wrap a plastic bag or similar round each and secure with a cable tie or similar.
A/C condenser.........just take your time when lifting the radiator out
« Reply #2 on: 29 April 2011, 23:06:25 »
Help needed...
Just remove the hollow bolts from the 'banjo' fittings on the gearbox oil cooler pipes. Be careful you don't lose the copper washers (2 on each pipe) but you'll only lose a small amount of oil and so won't damage your gearbox at all.  :y
You won't need to do anything with your air conditioning radiator (condenser) because it lives in front of the main engine radiator.  ;) ;)
fcc-pt
  • Portugal
« Reply #3 on: 29 April 2011, 23:08:38 »
Is there any problem if air enters the oil circuit?
What cares should I take with the aircon?
Is there anything in particular like an hidden screw or something?
Should I take the air inlet or no need for that?
« Reply #4 on: 29 April 2011, 23:12:42 »
Air intake is negligible.
Just make sure you don`t damage A/C condenser when removing rad.
No hidden screws, 3 electrical connectors on passenger side of radiator, two 8 or 10mm bolts either end of top of rad + the two inverted "U" spring clips on top corners.
No need to remove the "air inlet" (bagpipes)
« Last Edit: 29 April 2011, 23:13:31 by RobG »
fcc-pt
  • Portugal
« Reply #5 on: 29 April 2011, 23:14:42 »
I'm looking for a new radiator... those with plastic covers are really fragile, in particularly the plastic tubes! What is your opinion about it?
Anyway, when refitting the hoses can I apply any contact glue between the hose and the tube?
« Last Edit: 29 April 2011, 23:15:58 by fcc-pt »
« Reply #6 on: 29 April 2011, 23:16:23 »
No. The gearbox isn't completely full of oil/ATF and any way there's a breather on top of the gearbox.
You don't need to do anything with the condenser if you are just replacing the main radiator.
Not really.  :-/
I take it you mean all the induction pipes :-/ If so ..... Definitely!  :y :y
« Reply #7 on: 29 April 2011, 23:17:57 »
I disagree. you'll not get the new rad in passed the bagpipes if still fitted.  ;)
fcc-pt
  • Portugal
« Reply #8 on: 29 April 2011, 23:18:58 »
What about the fans? Is there any proper way to deal with it?
« Reply #9 on: 29 April 2011, 23:19:09 »
Replacement radiator will also have the plastic sides, not ideal but that`s the way they`re designed. No contact adhesive necessary on the hoses or spigots. If you did that how would you remove them if one of them split. Decent pipe clips are more than adequate.
fcc-pt
  • Portugal
« Reply #10 on: 29 April 2011, 23:20:30 »
Well it's really tight... maybe it's not a bad idea after all
« Last Edit: 29 April 2011, 23:22:25 by fcc-pt »
« Reply #11 on: 29 April 2011, 23:21:01 »
I stand corrected :-X Although I removed the rad from the breaker with the bagpipes in situ
fcc-pt
  • Portugal
« Reply #12 on: 29 April 2011, 23:26:15 »
What kind of clips is best? Because the last hose replaced by a mechanic costed me some extra money... the clip has stuck the hose... :(
So OK, pipe-bags will remain in place unless i can't move my BIG hands lol...
« Reply #13 on: 29 April 2011, 23:28:35 »
Use the original sprung hose clips & preferably not Jubilee hose clips.
Remove the bagpipes, you'll not manage to do the job at all with them in place.
fcc-pt
  • Portugal
« Reply #14 on: 29 April 2011, 23:29:06 »
Thank you very much...
Pages: [1] 2 3  All   Go Up
