Author Topic: speaker wires  (Read 1648 times)
geoff
  • thornaby,stockton on tees
speaker wires
« on: 30 April 2011, 17:27:42 »
can any body help me the solid colour wire and the line through wire,which is negative and which is positive,if anybody knows thanks :y :y :y :y
Martian
Re: speaker wires
« Reply #1 on: 30 April 2011, 17:31:52 »
It won't matter which is "positive" and which is "negative" where an AC waveform is concerned (audio is AC), all you have to worry about is that you observe the same polarity throughout if you don't want one speaker cancelling out another.
eg, if you decide the solid colour is positive where the speaker is concrned, you then observe the same wiring throughout.
« Last Edit: 30 April 2011, 17:32:34 by Martian »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: speaker wires
« Reply #2 on: 01 May 2011, 12:35:15 »
The solid is the positive
The one with a trace colour is the return  :y
geoff
Re: speaker wires
« Reply #3 on: 02 May 2011, 18:21:53 »
cheers thanks very much :y :y :y :y
Re: speaker wires
« Reply #4 on: 02 May 2011, 18:59:16 »
As Martian says, it matters not, as long as you are consistent :y
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: speaker wires
« Reply #5 on: 02 May 2011, 19:37:06 »
True, but in factory fitted situations, the wire with the trace is Negative.  :y
