Author Topic: alarms  (Read 1010 times)
mowerman
  • bedfordshire
alarms
« on: 02 May 2011, 15:41:36 »
my car has the standard factory alarm
it triggers about an hour after parking
any ideas engine cooling down perhaps
Re: alarms
« Reply #1 on: 02 May 2011, 15:56:49 »
Sounds like bonnet switch bracket is bent. Either bend it up or disconnect, see if it still happens. If it still persists, possible dying powersounder batteries
« Last Edit: 02 May 2011, 15:57:50 by RobG »
mowerman
  • bedfordshire
Re: alarms
« Reply #2 on: 02 May 2011, 17:57:13 »
thanks where is the sounder located
Re: alarms
« Reply #3 on: 02 May 2011, 18:15:21 »
http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Re: alarms
« Reply #4 on: 02 May 2011, 20:26:42 »
Had the same problem with my old estate. Turned out to be the pane-break on one of the rear side windows. Pop of the little black caps and use a thin filament of wire to short out the grid stuck to the glass. Do them one at a time to see which one is dodgy. Just a thought.. ::)
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
