Author Topic: help needed bad  (Read 2741 times)
Rayviator
  • Cardiff
help needed bad
« on: 30 April 2011, 14:44:52 »
for the last couple of days my 91 omega 3.2 has made a little chirp noise when i turn the ignition on and the turn over was slow. today it made the same little chirp noise and tried to turn over but stopped. now the started is just clicking so i pressume the battery is dead. why is this or is the imobiliser f**d. i really need help. i am in brussels and supposed to be on the 1205 ferry back to the uk on the 4th
Re: help needed bad
« Reply #1 on: 30 April 2011, 14:52:11 »
Chirping is the power sounder complaining that battery voltage is low so could be the battery dying. Whether that's because the battery is at the end of its' life, it's not being charged properly, or something is draining it when the car is parked up requires further diagnosis.
This is what you need to do:  http://www.omegaowners.com/forum/YaBB.pl?num=1225724099
I appreciate that it's not the easiest set of tests to do when stranded but a cheap multimeter from a hypermarket will tell you all you need to know.
Failing that, get a jump start and keep a set of jump leads in the boot. If, after a jump start, you can turn on a good amount of electrical load without the engine dying the chances are it'll get you to the ferry as long as you don't stop the engine!
The crimp connector at the battery positive terminal can be problematic and is something that's easily fixed. Check that this is not getting hot with the engine running and that the crimp where the large cable from the engine attaches is not loose.
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: help needed bad
« Reply #2 on: 30 April 2011, 14:54:22 »
It`s possible that it`s either the starter motor or solenoid, you`d be able to tell if it was the battery just by trying the lights.
Have you tried bump starting it down a hill or with the help of some kind strangers?
Might be worth a try just to get you going.
Rayviator
  • Cardiff
Re: help needed bad
« Reply #3 on: 30 April 2011, 14:57:50 »
thanks mate, soon as my flat mate comes home i will be scouring belgium for jump leads. i just have to get on the ferry. the rac can take me the rest of the way
  • Online Online
Re: help needed bad
« Reply #4 on: 30 April 2011, 14:58:15 »
Have you tried bump starting it down a hill or with the help of some kind strangers?....
It's an Elite Gav, chances are it's got a proper 2 pedal gearbox fitted!  ::) ::) ::)  ;D ;D ;D
Rayviator
  • Cardiff
Re: help needed bad
« Reply #5 on: 30 April 2011, 14:58:39 »
its an auto, so even though its on top of a hill for a good bump start, i just cant do it
  • Online Online
Re: help needed bad
« Reply #6 on: 30 April 2011, 14:59:50 »
Told you so Gav  ;) ;) ;) ;) :y
Rayviator
  • Cardiff
Re: help needed bad
« Reply #7 on: 30 April 2011, 15:02:06 »
andy knows his stuff
  • Online Online
Re: help needed bad
« Reply #8 on: 30 April 2011, 15:08:32 »
We have a long standing 'debate'  about auto's being the gearbox of choice.  ;) ;) ;)
Rayviator
  • Cardiff
Re: help needed bad
« Reply #9 on: 30 April 2011, 15:10:22 »
i belive you are right. as i spend my time arguing with my car about how it should work up and down germany and belgium, i feel the auto is a godsend to make driving nice
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Re: help needed bad
« Reply #10 on: 30 April 2011, 15:18:42 »
Yup, auto's rule.  :y
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Mr Gav
  • Leeds
Re: help needed bad
« Reply #11 on: 30 April 2011, 18:20:36 »
Just one more reason for the manual Andy, c`mon you know deep down that it makes sense  ;) ;D
  • Online Online
Re: help needed bad
« Reply #12 on: 30 April 2011, 18:25:57 »
I think you'll find that's the very reason why all good auto drivers buy themselves a decent set of jump leads so that they can jump start the manuals with flat batteries at the bottom of the hill.  ;) ;) ;) ;)
Mine have proved themselves invaluable over the years.  :y :y :y :y
davethediver
  • Blackburn, Lancs.
Re: help needed bad
« Reply #13 on: 30 April 2011, 19:11:13 »
;D ;D ;D ;D
P.A. Caron de Beaumarchais
Mr Gav
  • Leeds
Re: help needed bad
« Reply #14 on: 01 May 2011, 18:55:58 »
Jump leads are no good if you`re on your own smart @rse  ;D ;D ;D
