Author Topic: Water ,Rain ingress  (Read 3737 times)
jerry
Re: Water ,Rain ingress
« Reply #15 on: 03 April 2011, 23:03:56 »
glad Im not the only one with this problem! reading this with interest. Ive cleaned the scuttle out and checked windscreen seal and seems ok but in really heavy rain...Bit mystified as to where its getting through.
« Reply #16 on: 03 April 2011, 23:05:30 »
Well done on the 1000 Jerry. 8-) :y :y
jerry
« Reply #17 on: 03 April 2011, 23:17:12 »
Cheers Den-only just noticed! :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #18 on: 05 April 2011, 09:57:14 »
Bad luck Jerry What a nightmare, In the pollen filter area under the scuttle there are cable runs  with grommets  that go to the car interior which could be the problem and then of course maybe a weld seam leaking. Will have to take off all the bits under passenger area and hope to see where it is coming from. I will let you know what I find
cavman
« Reply #19 on: 03 May 2011, 16:09:51 »
I’ve got this issue and after much head scratching I’m convinced it’s evaporate from the Air-Con.
When I’ve got the Air-Con on, the evaporate usually runs out of two pipes, one either side of the driveshaft near the gearbox, on a humid day there is quite a lot.
I took up the carpet ect… and dried it out, I then drove in the height of summer to Austria, during which no rain fell by the time I got there the passenger foot-well was soaked in water.
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« Reply #20 on: 03 May 2011, 17:44:25 »
the passenger kickplate is indeed the triangular plastic bit that runs from footwell to underside of glovebox, (doorside) it is held in place by 2 scews one in a hole near the top (you can feel this) and another under the plastic door trim, this trim comes out by sliding the strip with the vauxhall logo on and then prising up you will then see the tork screws holding it in place, the second screw for the kickplate is under that  :y
the foam panel that runs along the underside of the glovebox is held on by big plastic screw things that just turn with a flat screwdriver, get your head in the footwell and you will see them  :y
hmm just remembered your problem so wear a bathing cap   ;D ;D ;D
... and don't forget to post the photos on here!  ;)
I feel like a military academy. Bits of me keep passing out.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #21 on: 03 May 2011, 19:25:35 »
Cavman Will be interested to know when you find the problem
