Author Topic: Oil Filter on 2.2 facelift  (Read 3052 times)
fudgee
« on: 02 May 2011, 14:15:05 »
I have what feels like a ridiculous question to ask.
Does the Oil filter on a 2.2 faclift turn clockwise or anti-clockwise when removing.
I'm right in the middle of an oil change and I've just drained the old oil and put the sump plug back in.
Gone to remove the old filter with my filter pliers and MY GOD!!!!!......that barsteward does not want to come off >:( >:( >:(
I'm turning it anti-clockwise but it's only moving a few milimetres at a time.
My knuckles on my left hand are bleeding where I keep whacking them against the fan and the filter now has dents all around it where i've been sqeezing so hard with the pliers.
Geoff capes could not have tightened it this much which is why i've stopped to come on here to check that I am auctually turning it the right way.
I don't want to damage it.
i'm a 16 stone guy who is pretty damn strong and I just cannot get it off.
Please help  :-/ :-/ :-/ :-/
Re: Oil Filter on 2.2 facelift
« Reply #1 on: 02 May 2011, 14:17:20 »
Anti-clockwise. I had to totally destroy mine
fudgee
« Reply #2 on: 02 May 2011, 14:22:28 »
Cheers Rob......I got to the point where I felt like smashing my car up so I thought i'd come on here and double check.
Did you just use pliers to get yours off like what I'm using, shall I just persevere with them?
thanks for the mega quick reply by the way mate
« Last Edit: 02 May 2011, 14:23:13 by mrfudge01 »
« Reply #3 on: 02 May 2011, 14:25:24 »
I got under the car, made a hole in bottom of filter body to drain as much of the oil out, then hammered a 16" long chisel right through the filter body and used that as leverage to undo it ;D ;D ;D ;D ;D
fudgee
« Reply #4 on: 02 May 2011, 14:32:44 »
Jesus.....you got hard core with it mate ;D ;D
I have'nt got a chisel so i'm going to go back and continue with my microscopic little turns.
As long as it's moving i'm assuming that it will eventually come off ::) ::)
Like i said, it is so abnormally tight I started to wonder if I was turning it the wrong way.
I'm off right now for a ten minute walk back to the car park on the housing estate near where I live.
Well I did'nt want to spill any oil outside my own Gaff did I  ;) ;) ;)
« Reply #5 on: 02 May 2011, 14:36:01 »
keep persevering with the pliers, but, if the filter body starts to collapse you may have to resort to similar actions as I took. Best of luck :y :y
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #6 on: 02 May 2011, 16:30:09 »
Or stab a long sturdy screwdriver through it  :y
« Reply #7 on: 02 May 2011, 19:00:57 »
Anticlockwise when looking UP at it. NOT anticlockwise when looking DOWN on it.
fudgee
« Reply #8 on: 02 May 2011, 20:28:03 »
I don't F*****G believe it!!!!!
All that time I was turning it the wrong way.
Unfortunatly as soon as I posted my last reply I went back to the car and took a screwdriver to it.
It's now completely destroyed and still won't come off
Theres only about the top inch of the filter left on with all razor sharp bits of metel hanging down which I've also sliced my forearm open on...(not joking)
I'm going to need to replace the auctual sump that it's sitting on, I don't know the name of it, it's got a few black rubber tubes attached to it and it's sort of a round shape.
Has anybody got one they want to sell?
If not do you know what it's called so I don't sound like a dick when i'm ringing round the scrappys.
I can't go back and try again to get it off because I'm going to literaly explode with rage and either hurt myself or someone else
« Reply #9 on: 02 May 2011, 20:35:39 »
I`ll accept part blame :-[. I thought you understood it was anticlockwise from below. Should have replied in a bit more detail for you. Sorry mate :(
fudgee
« Reply #10 on: 02 May 2011, 20:41:53 »
No apology required rob.....your intention was good and nobody forces anyone to take the advice on here which is always excellent.  :y :y
Is the part I need to source just called "the filter housing" or has it got another name?
It looks pretty straightforward to get off........or is it? :-?
sport
  • Stoke on Trent
« Reply #11 on: 02 May 2011, 23:04:30 »
I take mine to local garage charges me £10 to change oil + filter
« Reply #12 on: 02 May 2011, 23:15:07 »
Quality oil then ...........  ::) ::)
fudgee
« Reply #13 on: 03 May 2011, 19:24:53 »
Yes!!!!!!!!!!!!!!!!!!!! , despite what I said in my last post I decided to go and have one last go at getting the bugger off.
A hundred more swear word's and 50 more bang's to my hand and forearm later and the bloody thing is off.
I got a torx 45 socket and hammered it into one of the filter holes and then attached an extention bar which I used as a handle.
I also cut away some of the rubber seal with a stanley knife which helped a lot.
So my Oil change which started at about 11.00am yesterday finally got finished today at about 6.00pm ::) ::)
My car is now filled up with lovely new Mobil 2000 semi-symthetic.
I made sure I filled the new filter halfway up with the new oil and oiled the rubber trim before attaching as suggested by tunnie.
THIS IS WHAT MY OLD FILTER LOOKED LIKE ONCE FINALLY REMOVED
http://i1097.photobucket.com/albums/g357/eliciumpreview/Omega/OilFilter001.jpg
What a bloody drama!! :D :D :D :D
« Last Edit: 03 May 2011, 19:26:39 by mrfudge01 »
    • 530D M Sport, 330i Coupe
« Reply #14 on: 03 May 2011, 19:28:58 »
Splendid.... Fuel filter next then!  ;D
Seriously, well done for perservering sticking with it!
