Author Topic: What causes a misfire?  (Read 1663 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« on: 04 May 2011, 08:16:00 »
Only happens on LPG, it is a mixer system so fairly simple in operation, doesn't seem to be any pattern to when it occurs, only noticeable on acceleration, feels as though it just skips a heartbeat, VERY occasionally.
Breathers done, new spark plugs, runs fine on petrol.
No EML, no errors stored in ECU.
Have i missed anything??
Omega 2.6 V6 Elite in Shiny Black
Re: What causes a misfire?
« Reply #1 on: 04 May 2011, 08:18:10 »
LPG needs a stronger spark than petrol, but assuming the HT is OK, you have to look at the LPG mixer system
« Reply #2 on: 04 May 2011, 16:58:33 »
As above really... Could even be the coil pack breaking down :-/ But my first guess (and it is a guess!) is that the mixture is leaning out under acceleration. This is a situation you need to fix ASAP
But, as a word of warning, with a mixer system misfires can be very dangerous and lead to backfires which will do damage to the intake system :o :o
mark.adams
  • Cambridgeshire
  • Happy
« Reply #3 on: 04 May 2011, 17:45:20 »
Thanks guys,
i don't really know where to start with LPG, it's a BRC mixer system, i guess maybe looking for an air/gas leak on the intake is the first place to look...
« Reply #4 on: 04 May 2011, 17:48:49 »
Thanks guys,
It would be a start. Not really a suitable system TBH
« Reply #5 on: 04 May 2011, 17:55:24 »
I'm guessing (it is a guess) that a mixer to SGI is an easy enough conversion, given tank and pipework to engine is in place?
« Reply #6 on: 04 May 2011, 17:56:21 »
Depends... It's still a complete new Front end kit ;)
« Reply #7 on: 04 May 2011, 17:57:30 »
Indeed - but to retrofit is possibly easy, given coolant is (hopefully) in place to evap. Guessing you can't use same evap?
« Reply #8 on: 04 May 2011, 17:59:12 »
Can't use same vap, and coolant depends how it was plumbed in. Not too bad a job though :y
« Reply #9 on: 04 May 2011, 18:01:01 »
Just thinking aloud, given the trouble that mixers are...  ...though my experience is limited purely to tunnie's project shed...
mark.adams
  • Cambridgeshire
  • Happy
« Reply #10 on: 04 May 2011, 19:06:22 »
Well i'm up for it if you guys want to come onboard.
What do i need to buy?
Quick Q? With a SGI, if you turn the car off, the restart, does it start straight away, only with the mixer system, it needs to be turned over for a good 5 seconds before it starts on petrol after being used on gas....
« Reply #11 on: 04 May 2011, 19:50:03 »
It starts on petrol then switches over automatically! Have a look through the maintenance guides for the how to. Kit price somewhere around £250+vat :y
