Author Topic: Catera update...  (Read 1679 times)
WGoins88
  • Amherst, Ohio, USA
Catera update...
« on: 04 May 2011, 11:57:01 »
Well. I finally got the Catera running, after nearly 2 years of work and $650-675 USD.
Good news -
Runs great, no knocks, loud ticks, etc.
Good oil pressure
No overheating
No check engine light
The BAD news -
It has a blown head gasket. Yup.... that's right. A BLOWN head gasket (or a cracked head?). [smiley=embarassed.gif]
It's very obvious. It runs great, no coolant in the oil, but I have bubbling in the coolant tank and the clear smell of raw fuel. I've never been so angry in my life. I just feel like I wasted all this time and money for nothing!
I know I'm not replacing the head gaskets... I have no intentions of pulling it apart again unless it's to sell the engine if I part it out. It mainly has to do with the fact that I'd have to pull everything off that I put on it, plus I would need new cam sprocket bolts and such, which I'm not thrilled about.  >:(
1997 Catera - 75k miles
Vplatform.forumer.com
Re: Catera update...
« Reply #1 on: 04 May 2011, 12:08:41 »
Cam sprocket bolts can be reused in our experience. I doubt many who have put 3.0 cams in a 2.5 have ever replaced them and I can't recall a failure. I would suggest, if it's just been rebuilt with new gaskets, etc. you could reuse pretty much everything bar the head gaskets themselves.
A real pain that it's not behaving after all that work, though. >:(
WGoins88
« Reply #2 on: 04 May 2011, 12:35:33 »
Yeah, everything gasketwise is new. So since the the cam bolts are reuseable, it looks like I just might put new gaskets on it. But that's what peeved me off more than anything is I seriously thought about replacing the head gaskets when I had it torn apart. I should have done them.
« Last Edit: 04 May 2011, 12:36:24 by WGoins88 »
WGoins88
« Reply #3 on: 04 May 2011, 12:43:52 »
A quick question....
Would anyone recommend using the later (99+) MLS head gaskets over the older ones? I know they are more reliable, but was wondering if they would work fine.
I see the head bolts are the same throughout the years, so I would assume the later gaskets are fine to use as long as they are torqued to the 99+ specs?
« Reply #4 on: 04 May 2011, 12:53:12 »
UK engines went from 3.0 to 3.2 at the same time as the MLS gasket was introduced, I believe, and the bore size was different, so retro-fitting isn't an option.
We certainly see very few failures of the 3.2 / 2.6 gaskets, but they aren't exactly common on the earlier engines either. 99% of failures on those appear to be down to poor coolant servicing where the gasket material deteriorates from the waterway outwards until they leak, with the fire rings remaining intact.
WGoins88
« Reply #5 on: 04 May 2011, 13:05:08 »
Ahh, well in the US they went to MLS gaskets on the 3.0 in 99 (As you may know, we never had the 3.2 until the CTS), so I would assume they would work then, correct?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6 on: 04 May 2011, 18:59:50 »
Pardon me for being somewhat surprised if you had the heads off and didn't replace them. :-?
  • Auckland
    • Mazda MPV
« Reply #7 on: 04 May 2011, 20:17:13 »
Don't forget to use new stretch bolts for the cylinder heads. In my opinion/experience they are the only stretch bolts in an Omega/Catera that are taken way beyond their elastic limit and really are single use only.
WGoins88
« Reply #8 on: 04 May 2011, 20:48:05 »
Yeah, I know the head bolts are TTY and do intend on replacing them.
And yes, if I had the heads off, the gaskets certainly would have been replaced. It's just when I had it torn down to the heads, I seriously considered pulling the heads off to do the gaskets.
Shackeng
  • Ramsbury
« Reply #9 on: 04 May 2011, 21:01:54 »
Ah right, sorry, I misunderstood. :-[
