Author Topic: Temp Guage Sensor.  (Read 1654 times)
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Temp Guage Sensor.
« on: 03 May 2011, 20:55:13 »
Hi, just a quick question, is there a temp guage sensor (other than the 2 on the radiator) that the in car guage takes its readings from, and if so, where is it located? Thanks, and hope the question makes sense? :)
Re: Temp Guage Sensor.
« Reply #1 on: 03 May 2011, 20:57:19 »
Back of the engine between the "V". Single wire connector
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
« Reply #2 on: 03 May 2011, 21:03:12 »
Thanks Rob, been getting different readings so suspect the sensor is playing up?? I will see if i can locate it, and change to rule out. :y
« Reply #3 on: 03 May 2011, 21:03:38 »
 :o :o :o :o :o Wot?! No link?  ;D ;D ;D ;D ;D ;D
« Reply #4 on: 03 May 2011, 21:07:14 »
Was gonna take a pic of the one on the breaker but couldn`t be arsed ;D
« Reply #5 on: 03 May 2011, 21:08:04 »
« Reply #6 on: 03 May 2011, 21:10:18 »
By far the easiest way to locate it is......plenum off, inlet manifold off, then you can see it at the rear of the oil cooler to the left. :y
Waits for V6 owners to correct me :D ;D
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
« Reply #7 on: 03 May 2011, 21:20:39 »
Thanks again Rob...All that just to change a sensor, still if it solves the problem then well worth it. :)
« Reply #8 on: 03 May 2011, 21:22:13 »
Thanks again Rob...All that just to change a sensor,...
you've not seen where your thermostat is then  ::) ::) ::) ::)  ;) ;)
« Reply #9 on: 03 May 2011, 21:24:42 »
I saw it on the breaker. Straightforward jobbie apart from.................................................. ;D ;D ;D
« Reply #10 on: 03 May 2011, 21:27:13 »
mine's been OK for the last 7+ yrs (touches wood  ;)) and I intend the Omega to be gone before it ever needs a new one.  ;) :y :y
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
« Reply #11 on: 03 May 2011, 21:32:29 »
Thanks again guys, i know i will sort it out especially with the un-beatable help from the forum. :y :y
spanish_lad
  • spain
    • 1995 25XE saloon
« Reply #12 on: 04 May 2011, 21:32:27 »
found this thread cos i think that the thermostats gone on my v6 - both "top" rad pipes are empty and the engines getting .. warm ;)
is it really under the thingy in the middle of the V ?
if i hear "its dealer only" one more time im gonna set fire to the mig :p
« Reply #13 on: 04 May 2011, 21:41:15 »
Only one :-?
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #14 on: 04 May 2011, 22:05:25 »
Here's where the coolant bridge is, although it's tucked out the way on this pic
TC and BnQ Trade holder.
