Author Topic: how much does the (3.2) v6 engine weigh?  (Read 1942 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 04 May 2011, 20:04:44 »
anyone know what the weight is of the v6 engine alone?
ta
« Last Edit: 04 May 2011, 20:05:03 by ilovemyelite »
PM with your requests.
MutantCav
  • Gainsborough
Re: how much does the (3.2) v6 engine weigh?
« Reply #1 on: 04 May 2011, 20:10:28 »
With ancilliaries attached etc your looking in the region of 200-250kg so about quarter of a ton :y
« Last Edit: 04 May 2011, 20:10:49 by ShieldOfSteel »
humbucker
  • Cambridgeshire
« Reply #2 on: 04 May 2011, 20:11:59 »
thanks chris :)
Abiton
« Reply #3 on: 04 May 2011, 21:07:12 »
Wonder if they counted that when they were designing the wishbone bushes...  ::)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 04 May 2011, 21:12:40 »
Is it really that much?  I can quite happile shift one around on the floor without assistance.  I obviously cant pick it up  ;D   I was guessing around 140 - 170KG's.
« Reply #5 on: 05 May 2011, 09:40:24 »
My guess would be to the top end of that range. 160-170 kg. With all ancillaries it'll be a bit more, though.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 05 May 2011, 10:36:23 »
The engine lift i use lifts 250kg at the position i have it.
It easily lifts out the engine and autobox in one hit. So the engine has to be under 200 kg easy.
MutantCav
  • Gainsborough
« Reply #7 on: 05 May 2011, 11:08:18 »
An Omega saloon with an engine weighs in at about 1.5 tonnes, with no interior, engine or gearbox its 1.16 tonnes...gearbox with torque converter is 88Kg so 252Kg minus weight of the interior...pretty sure its about 220kg...but that does include the radiator, cats and other bits you would remove the get the engine and box out...
2woody
  • Northumberland
« Reply #8 on: 05 May 2011, 12:50:52 »
115 to 150kg undressed/dressed
(without the fluid boat-anchor)
« Reply #9 on: 05 May 2011, 13:08:47 »
Depends what the floor is ;) I can happily shift 350Kg of iron V8 around on my friends truck bed or his tiled garage floor, but I'd have no hope on my rough concrete garage floor (not that I'd want to, it'd wear through the sump a bit quick ;D)
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #10 on: 05 May 2011, 14:04:37 »
I'm just about to remove the heads from the spare 2.5 v6 engine I have here... I reckon there to be roughly 60-70 squids worth of scrap recoverable from that engine, in a few hours I should be able to let you know the precise weight!
« Last Edit: 05 May 2011, 14:10:19 by brikhead »
