Author Topic: ABS/ECU  (Read 1211 times)
OmegaGav
  • Hemel Hempstead
  • For god sake doooo something !!!!!
    • 08' Vectra 3.0 V6 Cdti
ABS/ECU
« on: 06 May 2011, 12:23:56 »
I currently have an intermittent ABS/TC failure which is staying at the same level of intermittent-ness ::)
Before i start removing the skin from my knuckles getting the main unit out is it possible there could be a fault with one of the ABS sensors/wires on one of the wheels ?
It seems that the ABS/TC lights are off when the car is cold but after 10-15 mins of driving they come on and the speedo fails, also the power steering dosent always go heavy and the speedo needle blips from time to time  :-? :-?
Yes it's my M&S goulash cannon. Ready Aim Fire...!!!
MutantCav
  • Gainsborough
Re: ABS/ECU
« Reply #1 on: 06 May 2011, 12:25:33 »
If the speedo fails at the same time then its the ABS/TC ECU... :-[
Varche
  • middle of Andalucia
    • Golf Estate
Re: ABS/ECU
« Reply #2 on: 06 May 2011, 13:29:36 »
Classic ABS ECU failure symptoms. Mine did that to start with before being on all the time.
You can get a S/H one for not much money but in my experience they fail fairly quickly (all about the same age now). For about £125 you can get yours reconditioned via BBA Reman darn Sarf or ECUtesting in Nottingham. Turnaround is pretty quick.  :y
OmegaGav
  • Hemel Hempstead
Re: ABS/ECU
« Reply #3 on: 06 May 2011, 22:11:18 »
Was clutching at straws whilst holding my wallet in the other hand  :-[ :-/ ::) so sending the ECU off for reconditioning is the way forward..............Bugger   :o
« Last Edit: 06 May 2011, 22:12:51 by OmegaGav »
