Author Topic: lpg help - getting 6mm pipe on the injectors  (Read 1184 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 06 May 2011, 18:30:34 »
I'm having a mare getting the 6mm piping onto the investors. What's best, a bit of heat on the tops of them?
Re: lpg help - getting 6mm pipe on the injectors
« Reply #1 on: 06 May 2011, 18:34:36 »
:o - thats normally dead easy - its the larger feed pipe to the injector block thats the real mare :o
Hot water to soften the rubber?
« Reply #2 on: 06 May 2011, 19:14:36 »
And a little fairy liquid to lube it...
Gaffers
« Reply #3 on: 06 May 2011, 19:38:25 »
I'll give it a go, I'm having a real problem getting them on  :(
Gaffers
« Reply #4 on: 06 May 2011, 19:41:06 »
By the way I take it that the small spring clips go on over the injection union to hold the pipe on...
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #5 on: 06 May 2011, 20:41:07 »
Talking to Teilo today about this , he says hot water will help or just chew on it for a while  ;) :y
His words not mine  :)
« Last Edit: 06 May 2011, 20:41:43 by tigers_gonads »
« Reply #6 on: 06 May 2011, 21:09:17 »
Yep, although they don't seem to do a lot. Both ends of the injector pipes and the vacuum / vapour pressure pipes.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #7 on: 06 May 2011, 21:42:12 »
I used a small amount of brake fluid
« Reply #8 on: 07 May 2011, 01:49:43 »
Aye? the rubber pipe goes on easy usually, it's the Polly pipe that's a pig, ESP the new stuff. Is it the correct piping? ( one wonders )  :-/
« Reply #9 on: 07 May 2011, 07:58:13 »
Man up! Those little pipes are reasonably easy to get on!
TBH... I usually use a little dribble in the end if it's difficult  :y
Gaffers
« Reply #10 on: 07 May 2011, 17:59:07 »
Well warming the pipe made it easier but still not straightforward on the nozzles.  The injectors were easy as there is more purchase.  I wonder if it would have been easier to fit the nozzles on the pipes first and then fit them to the inlet manifold?
Gaffers
« Reply #11 on: 07 May 2011, 18:09:38 »
Oh and the mamouth session working till 0030 last night and then again from 5am this morning. I got the car back on the road at 0800 having:
- plumbed in the vapouriser coolant pipe from the back of the coolant bridge around the front
- replaced the HBV
- replaced thermostat (and coolant bridge pipe  >:()
- replaced most of the coolant piping at the back
- fitted the inlet manifold that KW kindly tapped for me  :y
- replaced the leaking camshaft seal.
When I first started her up it ran fine at idle, and then I blipped the throttle and it was running of 4/5 cyl  :o  I was dredding that the cambelt had slipped but I definitely remember torquing it up correctly and making sure it was still set perfectly.  Then I realised that some rain water must have gotten in to the inlet after the thunderstorm hit during the rebuild.  I hurridly had placed the scuttle in place but obviously not well enough  :-[
After a few minutes with a rough idle a few studdering blips of the throttle cleared the last of the moisture and she was running sweet  8-)
End result:
- no more oil leak
- no more coolant seepage (not really a leak but was losing a litre a month plus the sweet smell in the cabin)
- a more normal running temperature
- increased mpg
- smoother
- more power
The last 3 were a pleasant suprise but definitely noticable.  But the whole session last night and this morning was not a pleasant one after playing a whole day of rugby league 9's tournament when you're mid 30's.
Now to fit the rest of the kit  :y
