Author Topic: Spraying  (Read 1555 times)
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Spraying
« on: 08 May 2011, 02:01:54 »
Hi all, I am replacing the drivers door handle and front grille ( kindly supplied  by VX1) I've got my paint, primer etc, but before I start has anyone got any tips on doing this job or are there any good links to any step by step guides?
Cheers, Jon :y
Jon
dragonlord
  • luton
Re: Spraying
« Reply #1 on: 08 May 2011, 07:53:02 »
what paint you get ?
if its halffors crap dont bother
with decent paint
ie mixed at local factors and put in there cans
warming cans in warm water helps stop can spiting
proper gear and compressor better option
rub down/flat with 600 grit
wipe down so greas and dust free
dont even thing of spray if panels is colder than 10degC
spray primer prity easy to spray
if you cant spray primer give up now  ;D
spray a guide coat
rub down flat with 800 grit
spray color much harder to spray
dont lay it on too much light even coats
clear coat very hard to spray right with out practice
do dot spray if it humid as it will milk
spray tac/light coat let flash too its still a bit tacky
lay on next coat wet all most to point of runs very hard to do with out practice
if you want a show finish flat with 1200 grit
and re-polish buff to mirror finish
if you aint painted much go to local body shop and save your self the ball ache
the above is the short guide
as there much that can go wroung
my best advice is call you local smart repair guy and hell problem do it for 50 quid or less
it will be cheaper as by time you brought paint paper get pissed off cleaner
it will be cheaper any way and he do a puck job :D
« Last Edit: 08 May 2011, 08:03:35 by outlaw1234 »
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Re: Spraying
« Reply #2 on: 08 May 2011, 08:51:04 »
Thanks Dragon, I got the paint and lacquer from Vauxhall. I'm giving it a go myself, as they are both only small areas to paint. Would you rub down the old paint off completely or just smooth them down before priming.
Jon :y
Jon
Big_Al
Re: Spraying
« Reply #3 on: 08 May 2011, 09:31:34 »
Cheers, Jon :y
Jon ,there is a section on aerosol spraying in the maintenance guide.
Its under Trim, cosmetic & body in the external section.
Sorry can't give you the link . No good with PC's
you can get good results - more so with small items & areas -  but patience is the key. good luck :y
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Spraying
« Reply #4 on: 08 May 2011, 09:33:02 »
just rubbing down will be fine, take the original paint sheen off so the primer has something to grip to, p600 will be fine  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Spraying
« Reply #5 on: 08 May 2011, 09:40:18 »
Jon :y
If you're just changing the colour on good parts, particularly plastic ones, I wouldn't rub them down at all. Use a fine scotchbrite pad(grey I think) to scuff them up so that the paint sticks, and go from there.
That way, you won't need  to flat the primer much, which means probably only needing one coat of it, if it needs any at all.
Then apply the colour, as previously stated, in several very light coats, leaving at least 10mins between them so you avoid runs.
Apply the clear the same way, especially the last couple of coats, as it MAY dry to a nice finish. I don't have much luck with aerosols, so repainted the mirror housings on my mum's Focus this way, but used 2pack clear and a touchup gun.
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Re: Spraying
« Reply #6 on: 08 May 2011, 09:53:03 »
Thanks for all the replies :y
Jon
Page created in 0.01 seconds with 14 queries.
