Author Topic: Passenger seat height adjust failure  (Read 1294 times)
Clarkey
  • Ireland
    • 01 3.2 Auto Executive
« on: 10 May 2011, 22:04:59 »
Have a 01 Omega with elec. seat height adjustment. When I operate the switch to adjust height I just get a clunk but no movement. Is it motor failure as I suspect or is there something seized in the seat base? Any advice appreciated. :y
unclelicklug
  • Sheffield
Re: Passenger seat height adjust failure
« Reply #1 on: 10 May 2011, 23:03:40 »
Almost certainly just a sticky adjuster - there's a good guide somewhere on here to freeing this and I'll go and have a look for you......from memory, in short go into the back seat, get down and pull off the plastic cover at the bottom of the seat and then you can send a socket (13mm?) down the hole and operate the mechanism by hand for a few turns.
Once you get it moving again the motor will be able to operate fine.
unclelicklug
  • Sheffield
Clarkey
  • Ireland
« Reply #3 on: 11 May 2011, 11:40:46 »
Great stuff. Thanks for that. :)
unclelicklug
  • Sheffield
« Reply #4 on: 11 May 2011, 13:05:35 »
Most welcome, any credit really belongs with Mark and all the other guide authors, more guides here...
http://www.omegaowners.com/forum/YaBB.pl?num=1259003779
« Last Edit: 11 May 2011, 13:06:33 by unclelicklug »
Page created in 0.103 seconds with 16 queries.
