ecu
Started by davebu, 11 May 2011, 18:33:12
davebu
were is the ecu on the omega 2.2dti
Engine,alarm,gearbox, airbag :question
davebu
QuoteEngine,alarm,gearbox, airbag :question
engine
davebu
its the engine ecu
Would have thought same place as petrol Omega`s. Triangular relay box under bonnet by battery
davebu
thanks will have a look now
davebu
found it now it was where u said thanks
Brikhead
Usually it's the one on the fuel pump that causes problems...
davebu
had car to local vauxhall dealers they say i need new ecu and immobiliser car runs in limp mode.has anyone used the ecu doctor?
Where are you located, some members on here with TechII who actually know how to use it
Quote.... car runs in limp mode. .....
Do you have a Engine Management Light on? If not does the light work ie light when you first turn the ign on.
Brikhead
Quotehad car to local vauxhall dealers they say i need new ecu and immobiliser car runs in limp mode.has anyone used the ecu doctor?
Ask them for a print out of the fault codes that led them to that conclusion.
Take no notice of them
davebu
vauxhall checked all wiring engine management light works but not on constant ecu will not connect to diagnostic computers
I very much doubt it is the ECU. *VERY* much doubt.
Vauxhall dealers don't use the brightest sparks in the fire, if you catch my drift - they can't at the money they pay them ;)
Updating your location may help, somebody nearby might be able to diagnose better than the dealer ;)
