Might not be the rear bearings after all.........
Started by MV6Matt, 12 May 2011, 07:31:02
MV6Matt
......mechanic drove it yesterday and and said it sounds more like the diff than the bearings.
So, if this is confirmed, are rear diffs from breakers worth installing or should I go new? :-/
(I guess this is a case of Mega-bucks :'( vs quite cheap ::))
Any thoughts?
Matthew
(thanks Ian)
MV6Matt
QuoteI take it you've checked the Diff oil?
Will be doing that when the Car's up in the air to check what's going on - but not yet.
If the diff oil is not at correct level/volume (don't know haw it's measured) is the seal/plug an easy replace?
Matthew
(thanks Ian)
if you plan to keep the car I would bite the bullet and buy new.. god knows how long will go an old one..
Generally robust enough, assuming it has oil in.  I'd be inclined to get one from a breaker - non LSD ones seem to be thrown away as nobody wants them.
Remember, the ratios vary in the diff though.
I'd love to know how much Vx would quote for a brand new diff ;) change from £1000?
MV6Matt
QuoteI'd love to know how much Vx would quote for a brand new diff ;) change from £1000?
Yes, mate, exactly..........................
frightening isn't it?
Matthew
(thanks Ian)
Matthew
Personally I'd do what TB said though, if it needed a diff - go s/hand.. these things aren't exactly common points of failure (unless they're run dry of oil, that is).
2woody
I've just rebuilt a diff for one of mine. Over £400 in parts alone.
MV6Matt
QuoteI've just rebuilt a diff for one of mine. Over £400 in parts alone.
breakers it is then..................
(thanks Ian)
jiho102
Had a second hand diff put on my old girl (£110-00p Delivered)
a few months back and touch wood is running fine and very quiet indeed instead of that continous humming noise.
OH, and heres the main thing, I phoned up a VX main dealer for a laugh just to find out how much a new diff on mine would cost, 2.5 V6 auto.
                       about,      £2000-00p (no lie) :o
Hello Matt, [smiley=vrolijk_26.gif]  :D ::)......would need to check ratio though. ;)
MV6Matt
QuoteHad a second hand diff put on my old girl (£110-00p Delivered)
:o :o :o :o :o :o
Well, that confirms everything! Here's hoping that that won't be necessary!
Matthew
(thanks Ian)
MV6Matt
Ta
You have PM
(thanks Ian)
