Author Topic: Rattling Door Buttons  (Read 2711 times)
stumpage
« on: 11 May 2011, 15:48:40 »
All 4 internal door buttons rattle on my 2001 Omega. Any tips on how to stop this?
Thanks
Re: Rattling Door Buttons
« Reply #1 on: 11 May 2011, 16:15:36 »
Thanks
remove the pins, wrap insulation tape around the bottom part, re-fit.  ;)
« Reply #2 on: 12 May 2011, 02:43:18 »
The felt has worn away from the moulding around the pin, I tried tape, it didnt last, nor did half a piece of Velcro. Stuck down the side.
I tried bending the rod so it leans the pin back towards the widow a fraction and takes put the play. Only did it on the drivers door to see, but didn't quite bend it enough as it still rattles, it's better, but.... Work in progress this one for me.
Wondered if the plastic surround with the felt in is available separately? I know the door cards are no longer available new.
« Reply #3 on: 12 May 2011, 04:55:19 »
Mmm, I will have 4 spare door cards shortly. Must have a careful listen and see if they rattle. If they do I havent  noticed. :) ::)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #4 on: 12 May 2011, 06:21:38 »
I've used black "electricians tape" on two cars with success  :y One option would be to change the pins to "older model".
« Reply #5 on: 12 May 2011, 08:09:04 »
My drivers is the same... ...next time I remember, I was going to raid Mrs TB's craft box for more felt ::)
« Reply #6 on: 12 May 2011, 09:52:12 »
Maybe i've got cheap electrical tape. With the action of the door pin, and I guess heat in the car, anything I've stuck on has fallen away.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #7 on: 12 May 2011, 10:00:40 »
Happens to me on occasions also.
How do you get the pins/buttons out exactly ?
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #8 on: 12 May 2011, 10:31:06 »
Carefully prise out the red tab, with a very small screwdriver or similar. It moves outwards but does not fall off (always ;D), then the pin can be removed.
As said, I have succeeded with the tape, a few rounds usually does the job. Put it just below the red tab so it will not be visible. Put too much and it will peel off, just enough to stop it rattling.
Clarkey
  • Ireland
    • 01 3.2 Auto Executive
« Reply #9 on: 12 May 2011, 12:54:12 »
Thanks
They all rattle to some extent. Just lock the doors and no more rattle (or not as bad at least).
« Reply #10 on: 12 May 2011, 16:20:31 »
Thanks
Not in my experience ;)
ndmv6
  • huddersfield
    • 2001 2.2 auto cd
« Reply #11 on: 12 May 2011, 21:37:45 »
all mine rattle,i just lock the drivers door when driving,they all pop down,rattle gone,easy fix..:@)
Boiler Man
  • Sale, Manchester
« Reply #12 on: 12 May 2011, 23:57:41 »
Thin foam household door draught excluder inside the plastic surrounds that the pins move through.
Our if it is thick, just on one side.
Worked on mine.
Maybe it is just me, but I dont like the idea of the doors being locked when driving.
What if your in an accident and can't be pulled out, coz your doors are locked :o
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
« Reply #13 on: 13 May 2011, 00:32:24 »
Worked on mine.
Isn't there something in place to unlock the doors in such a case? Linked to air bag maybe?
« Reply #14 on: 13 May 2011, 07:35:09 »
Worked on mine.
I would have thought so, although I must admit, I don't like driving around with the doors locked either ;)
