Pages: [1] 2 3  All   Go Down
Author Topic: servotronic relay  (Read 4166 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
servotronic relay
« on: 08 May 2011, 15:56:18 »
Hi all,
Trying to locate the relay for the power steering on my f/l. Looked in the panel under the steering column but can't see it. Any idea what position number/sign it is please?
I'm going to swop the relays over onto my mini facelift to see if that is why my steering is heavy at low revs.
TIA  :y
AKA - Mr Bracket
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: servotronic relay
« Reply #1 on: 08 May 2011, 16:04:39 »
hmmm in a facelift it should be under the steering coloumn behind the fusebox  :-?
the only info i can give you is that they are hidden quite high, quite difficult to see but it is red  :y
looking at your profile you say you have a 99 f/l so im wondering whether the relay is behind glovebox as it is in mfl  :-/ :-/
fiend61
  • york
  • each to their own
« Reply #2 on: 08 May 2011, 16:09:05 »
hmmm just reread your post
do you mean the fuse box?? if so you are looking in wrong place  :(  get your head in footwell and take felt trim off above pedals but under fusebox the relays are up in there behind the fusebox :y
« Last Edit: 08 May 2011, 16:12:26 by fiend61 »
blackviper90210
« Reply #3 on: 08 May 2011, 16:20:33 »
Haha, was looking in the wrong place then..  :-[ :-[ :-[ :-[
Will go & have another look!
I'm taking it off my facelift to try on the mini facelift to check if that is the fault before changing the steering pump.
I was advised that yesterday on here, so learning as I go!
Cheers for that.  :y
AKA - Mr Bracket
« Reply #4 on: 08 May 2011, 16:23:02 »
Remove passenger kick panel look up and it`s the red one.
fiend61
  • york
  • each to their own
« Reply #5 on: 08 May 2011, 16:40:25 »
thought in a mfl it was behind glovebox rob and in a f/l behind fusebox  :-/
« Reply #6 on: 08 May 2011, 16:44:34 »
I might be wrong, but facelift 2.0, 2.5 & 3.0`s are behind pass. kickpanel. The breaker (F/L "Y" reg 3.0ltr was behind kickpanel `cause I got it in the shed ;D ;D ;D ......around the £70 mark from VX IIRC
blackviper90210
« Reply #7 on: 08 May 2011, 16:45:21 »
I must be blind today. Just been out again to the f/l, taken the kick panel down and looked up behind the fusebox.
All I can see is a plastic panel approx 1" sq running from across the back of the fusebox with a bunch of wires running above it. Put my hand up and had a poke about but can't see or feel anything??
Someone shoot me and put me outa my misery!  :'(
AKA - Mr Bracket
blackviper90210
« Reply #8 on: 08 May 2011, 16:47:10 »
That might be why then. Was told it was drivers side kick panel, not passenger side!
AKA - Mr Bracket
« Reply #9 on: 08 May 2011, 16:48:58 »
Go out there and have another go then ;D ;D
blackviper90210
« Reply #10 on: 08 May 2011, 16:50:21 »
On my way Boss!   ;D ;D
AKA - Mr Bracket
blackviper90210
« Reply #11 on: 08 May 2011, 16:57:29 »
Well I think I've hit the jackpot this time. Found 2 large blocks, 1 grey, 1 red!
Next question, do they just pull out or is there clips holding them? Just tried to get the red one out, but its bloody cramped and awkward to get at!
AKA - Mr Bracket
« Reply #12 on: 08 May 2011, 16:59:31 »
Pull out, bloody stiff. You can try using a small bladed screwdriver to gently lever around the base
fiend61
  • york
  • each to their own
« Reply #13 on: 08 May 2011, 17:01:37 »
as rob says  ;D ;D ;D
fiend61
  • york
  • each to their own
« Reply #14 on: 08 May 2011, 17:04:01 »
this is going to be annoying if it is the pump and not the relay  ::) ::)
Pages: [1] 2 3  All   Go Up
