Author Topic: ATF fluid  (Read 1519 times)
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
ATF fluid
« on: 14 May 2011, 12:30:43 »
How do I identify which type of auto box is fitted into my car a year 2000 2.2 petrol as i am going to do a ATF change and need to order some gaskets and a filter, also reading on the forum i see that the recommended ATF to use  is Dexron 3, now as all of the fluid will no be changed  would it be ok to use castrol OX-75 automatic transmission fluid which is To GM 6417M specification. as I have 10 litres of this sitting in the shed  :) :)
richdrury
  • mildenhall, suffolk
    • 2000 2.5 v6 cdx facelift
Re: ATF fluid
« Reply #1 on: 14 May 2011, 12:43:46 »
the box will be an AR25, and the fluid meets GM specs so should be ok to use
Re: ATF fluid
« Reply #2 on: 14 May 2011, 13:01:59 »
Any oil meeting Dexron III should be suitable.
Its my personal hatred of anything that comes in a Castrol tin that would stop me putting that in.
My own preference is Fuch Titan 4000
hazpaker
  • deepest Norfolk
    • 2.2 petrol cd
Re: ATF fluid
« Reply #3 on: 14 May 2011, 22:09:38 »
thanks for the swift replies guys much appreciated
Hannah Judes Dad
    • the misses round the bend
Re: ATF fluid
« Reply #4 on: 15 May 2011, 19:48:03 »
OX-75 is also the military name for dexron 3 ,at the moment it is manufactured by fuchs-silkolene  :y
Martin_1962
Re: ATF fluid
« Reply #5 on: 15 May 2011, 20:37:52 »
Common thoughts - I wonder why?
