Author Topic: Plastic skin/seal for doors  (Read 1600 times)
MV6Matt
  • London
    • No car since 2022....
« on: 16 May 2011, 17:58:20 »
I'm about to replace the front passenger door airbag sensor.
I've got to remove the thin plastic skin to get at the wiring on the bottom strip (to check that too) and remove/replace the sensor.
Any tips for suitable adhesive to use for re-sealing when I'm putting everything back? Or will it remain sticky enough to re-affix without additional adhesive/
Anyone know?
Matthew
(thanks Ian)
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Plastic skin/seal for doors
« Reply #1 on: 16 May 2011, 18:00:55 »
Mine usually get 'Gaffer taped' back on... This may not be suitable for vehicles equipped with side air bags though, hopefully somebody with more knowledge can advise!
« Reply #2 on: 16 May 2011, 18:20:22 »
Anyone know?
Matthew
Yes, as long as it`s peeled back carefully.......and try to avoid any splits/rips
crossy
  • Ireland
« Reply #3 on: 16 May 2011, 18:31:40 »
I Put mine back on the first time with nothing on it.
The second time I used silicone. Peels away easy enough and holds it in place too
Drive her straight sideways
MV6Matt
  • London
« Reply #4 on: 16 May 2011, 18:43:59 »
Anyone know?
Matthew
Thanks Rob!
Matthew
(thanks Ian)
MV6Matt
  • London
« Reply #5 on: 16 May 2011, 18:44:50 »
Thanks Crossy - I like your Car!
Matthew
(thanks Ian)
