Author Topic: Broken part in 2.5td anyone tell me what it does  (Read 2892 times)
crossy
  • Ireland
« on: 15 May 2011, 22:48:07 »
This part is broke in my car.
There is no numbers on it to look it up and there is no words on it.
Can anyone tell me what it is and what it does.
It has a big red dot on it in the photo.
Thanks
Drive her straight sideways
Re: Broken part in 2.5td anyone tell me what it does
« Reply #1 on: 15 May 2011, 22:50:52 »
MAP sensor - it tells the ECU how much air is going into the engine (well, actually it tells the ECU what the air pressure is in the inlet manifold).
It's .. quite important!
crossy
  • Ireland
« Reply #2 on: 15 May 2011, 22:58:07 »
ok well the little pipe is broke off it and the car still runs. Would a new one be recomended? would the car lack in power because of this?
« Reply #3 on: 16 May 2011, 10:20:29 »
In traditional terms, its the boost sensor.  Most cars would drag on EML, but that being BMW, that would harm their perceived higher reliability ;)
Yes, its importnat, and yes, it will cause the engine to run sub optimally
crossy
  • Ireland
« Reply #4 on: 16 May 2011, 11:28:32 »
Cheers guys. May get a new one so :)
crossy
  • Ireland
« Reply #5 on: 16 May 2011, 11:53:52 »
The pipe going into the map sensor is blowing out a bit of oil.
Is this normal? Will in clog the sensor?
« Reply #6 on: 16 May 2011, 19:08:05 »
Yes, its the blow by gases escaping by the easiest route e.g.....the borken pipe.
The blow by gases will have some oil content.
The sensor has no through passage so when connected correctly no harm will be done.
« Reply #7 on: 16 May 2011, 19:23:36 »
I guess the turbo seals, given some miles, may generate a samll amount of oil in the intake as well...
« Reply #8 on: 16 May 2011, 19:24:58 »
Possibly but not so likely on TD's as they have a much easier life than turbos on petrols
crossy
  • Ireland
« Reply #9 on: 16 May 2011, 19:26:06 »
Cheers for that guys.
Pitty its another €129.00 + vat off the garage
Already after putting two new shocks in it this month aswel as all the bushings and track rod ends
The joys of motoring :) ;D
« Reply #10 on: 16 May 2011, 19:27:42 »
Reliable enough (if you aren't ham fisted ;D) to use one from a breaker ;)
« Reply #11 on: 16 May 2011, 19:29:16 »
Funny you should say that - there's a 2.5TD on fleabay at the moment listed with a 'blown turbo' .. I have my doubts a about that and I'm almost tempted to take a punt on it for precisely the reason you say.
Bejeezus! Did you buy it already? If not, I have a used as-far-as-I-know-good one sitting in the toolbox that you're welcome to for the price of postage and a wee bit to cover a couple of drinks? (Took it off my old 2.5TD when I was playing find-the-fault-that-turned-out-to-be-the-autobox ;D, it wasn't throwing any codes so I believe it to be a good sensor; they're electrically very reliable)
« Reply #12 on: 16 May 2011, 19:29:49 »
Given the entire state of the intakes on these TDs, I would hazard a guess that the majority of the oil in the TD intake has come from the turbo - would have thought if it was just blow by, is would hit a brick wall long before the turbo, but the oil starts just beynd air filter normally...
« Reply #13 on: 16 May 2011, 19:30:58 »
I think I got cheesed off with TD parts cluttering my garage, so sent it all to landfill :(
crossy
  • Ireland
« Reply #14 on: 16 May 2011, 19:31:17 »
Guess 210,000 miles do this to a car ha
