Author Topic: DONE CAM BELT CHANGE - NOW IT RUNS RUBBISH!  (Read 12172 times)
DTC
  • Birmingham, West Midlands
« on: 08 May 2011, 21:29:20 »
I have just completed a cam belt water pump and auxillary belt change on my lovely V6  and now it runs like a piece of farm machinery!
I changed the plugs whilst i had easier access and when I discovered the problem I put the old ones back in but this hasn't cured it.
I am motoring on a budget and am scared to take the car out at all like this. Can anyone please offer any advice?
Re: DONE CAM BELT CHANGE - NOW IT RUNS RUBBISH!
« Reply #1 on: 08 May 2011, 21:30:57 »
Either timing is out or you`ve not re-connected a plug somewhere. Any codes on the pedal trick :question
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 08 May 2011, 21:35:38 »
Possibilities are:
Air leak
Dis pack plugged in wrong (if disturbed)
Timing out
Something unplugged
Is the eml on?
DTC
« Reply #3 on: 08 May 2011, 21:36:36 »
Pretty sure i have re connected all the plugs - how would the timing be out? I know i didnt use the locking kit, but was advised by other mechanics you didn't need the proper kit? Wold it really send it this bad?
What's the pedal trick?
DTC
« Reply #4 on: 08 May 2011, 21:37:38 »
Emi flashes for a bit then goes to permanent spanner
« Reply #5 on: 08 May 2011, 21:39:42 »
Unfortunately you've been given bad advice :( To get the timing spot on you must use the correct Locking/Timing tools.
If you haven't got the timing spot on how it used to be, which is probably what has happened, it will run rough
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #6 on: 08 May 2011, 21:39:58 »
Because you need a locking kit to do it properly.
TuBy's new whipping boy.
« Reply #7 on: 08 May 2011, 21:40:02 »
Oh break :o
You do need a timing kit, it simply cannot be done without it.  Don't listen to any retard who says it can
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #8 on: 08 May 2011, 21:41:09 »
You have answered your own question mate, you have not used a locking kit. .  :-?
« Reply #9 on: 08 May 2011, 21:42:42 »
....how would the timing be out? I know i didnt use the locking kit,  ....
you've pretty much answered your own question.  ::)
Put another way, if you didn't use a locking kit, can you be sure the timing is correct?  :-/
« Reply #10 on: 08 May 2011, 21:42:57 »
At best, you may just need to retime it using proper kit, and reset tensioner (you did change the tensioner and the idler pulleys?).
At worse, you may have some bent valves  :'(
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #11 on: 08 May 2011, 21:43:05 »
Hope you have not got more than 2 teeth out else good night 24 valves  :-?
DTC
« Reply #12 on: 08 May 2011, 21:44:40 »
have I done any damage? I should have used the correct locking kit I know now- but for £65 for something i would use once seemed a lot of money to just leave on a shelf once used . Just had a new born and the cam kit and pump just cost me enough!
« Reply #13 on: 08 May 2011, 21:44:52 »
... it simply cannot be done without it.  ....
It can be done, just not very accurately, and it's not easy to see the mark on the crank.  ;)
« Reply #14 on: 08 May 2011, 21:46:12 »
have I done any damage? .....
We don't know how far out your timing is. I doubt your pistons have met the valves .............. but who knows.  :-/ :-/
