Author Topic: ABS ECU Refurbs  (Read 1421 times)
ChrisWallMV6
  • Chesterfield
ABS ECU Refurbs
« on: 16 May 2011, 20:02:34 »
Who is best for these? Havn't got a huge budget and hear they are a pain in the backside to remove too :/
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: ABS ECU Refurbs
« Reply #1 on: 16 May 2011, 20:13:24 »
Either BBAreman or ecutesting.com :y
other rides
gerry c
  • derry
Re: ABS ECU Refurbs
« Reply #2 on: 16 May 2011, 20:19:17 »
on the topic of ABS is it true that a faulty abs pump wont show up on fault codes??
i replaced my ABS bulb as the cowboy previous owner took it out to hide the fact that the ABS aint working, and the light stays on. when braking hard the car locks up, what should i look at next apart from another car lol.
henryd
  • west cornwall
Re: ABS ECU Refurbs
« Reply #3 on: 16 May 2011, 20:25:53 »
If your speedo and power steering are working normally it may not be the ecu, could just be a duff wheel speed sensor. You need to get it plugged in to be certain
other rides
gerry c
  • derry
Re: ABS ECU Refurbs
« Reply #4 on: 16 May 2011, 20:58:49 »
speedo and power steering work fine, he hooked it up earlier and found no faults :-? taking it back tommorow
ChrisWallMV6
  • Chesterfield
Re: ABS ECU Refurbs
« Reply #5 on: 17 May 2011, 19:45:43 »
Thanking you kindly :)
I'll be asking a lot of non-sensical questions in the coming weeks, expect it!
henryd
  • west cornwall
Re: ABS ECU Refurbs
« Reply #6 on: 17 May 2011, 20:03:24 »
hope you get sorted :y
other rides
ChrisWallMV6
  • Chesterfield
Re: ABS ECU Refurbs
« Reply #7 on: 17 May 2011, 20:17:54 »
Got a bit of a jobs list to be cracking on with, niggly things I want to get right!
This one is the one I've been dreading after reading up!
