Author Topic: Looking for a level surface on the vehicle  (Read 1063 times)
Echo Beach
« on: 17 May 2011, 19:11:25 »
Received wisdom is that one should check Oil, and the like, on a level surface.
My drive is not level.
Does anyone happen to know whether there are any surfaces, inside or outside of the car, which I can use to check that the vehicle is level, please?
Echo
Re: Looking for a level surface on the vehicle
« Reply #1 on: 17 May 2011, 19:15:20 »
it only needs to be rack o' th'eye  ;)
ie near enough by eye  :y :y
« Reply #2 on: 17 May 2011, 19:16:28 »
Front of car facing down gradient............jack in centre of front support beam, door open, spirit level on sill, jack away `till level
Andy........eyesight might be crap :D
« Last Edit: 17 May 2011, 19:17:13 by RobG »
« Reply #3 on: 17 May 2011, 19:42:51 »
Specsavers ?  ;)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #4 on: 17 May 2011, 19:44:48 »
Echo Beach,
As posted, any reasonably level piece of road / driveway /hard standing will be sufficient to get an accurate oil level reading.
No offence intended, but it's surely not worth all the effort of jacking the car and getting busy with a spirit level ??
Echo Beach
« Reply #5 on: 17 May 2011, 20:48:59 »
Thanks for your responses.
I hadn't planned to resort to using the jack.
It sounds like the closest (to level) surface are the door sills.
Thanks
Echo
