Author Topic: Replacing the rear wing.  (Read 1113 times)
stevepugh
  • Wellingborough
« on: 18 May 2011, 11:50:05 »
Had a little accident with the car. (someone ran in to the back of it)  Damage looks to be localised to new rear bumper and rear n/s wing.   If this was a front wing it'd be easy and bolt on, but the rear is a little more complicated.
Has anyone tackled this and got any guidelines to how I would go about replacing this?
Thanks.
crossy
  • Ireland
Re: Replacing the rear wing.
« Reply #1 on: 18 May 2011, 13:10:10 »
You may get a pro to do it. It has to be welded perfect and the welds sanded out and filled and all sorts.  Just get a new quarterpanel is only way to fix it. Take it to a legit body shop, because you probably cant weld/body work and at least there they know what anti-corrosion measures to take
Drive her straight sideways
scimmy_man
  • yorkshire
« Reply #2 on: 18 May 2011, 17:53:09 »
Its probably less work to knock the dent out, and fill than replace it.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 18 May 2011, 19:01:06 »
I agree,changing a rear wing is a pretty big job
other rides
