Author Topic: TD using water,  (Read 1277 times)
osealy
  • dublin
TD using water,
« on: 18 May 2011, 17:57:40 »
About 1l every 500mls or so.  It's not dripping on the ground. Could it be a weeping rad/hose & it's just evaporating?  Head gasket? Engine runs fine 155k mls.
charlie
  • sunderland
Re: TD using water,
« Reply #1 on: 18 May 2011, 18:10:28 »
Have you checked the hbv,MIne would not leak,felt dry until i got someone to put full revs on then the leak was bad, out of the hbv
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: TD using water,
« Reply #2 on: 18 May 2011, 18:25:30 »
As said, hbv failure is quite common on Vauxhalls, check for leaks or drips on the ground while the engine is running.
Also look for the tell tale signs of crystal formation to pinpoint any weepy hoses etc.A garage can do a quick 'sniff test' to check for head gasket failure...
osealy
  • dublin
Re: TD using water,
« Reply #3 on: 18 May 2011, 22:17:55 »
I'll look at HBV if I can find it. Is there a DIY "sniff test" as I'm allergic to garages.
