Author Topic: Intermittent Stalling ? ?  (Read 2195 times)
DeRangeRC
  • The Peak District (mostly)
  • Taking it on one job at a time.
« on: 09 May 2011, 23:06:50 »
Hey all,
I have a very intermittent stalling fault on my T reg 2.0 petrol Auto.
It usually happens when the engine is warm and usually when you come to a stop, say in traffic and sometimes when you slow down to turn which can be a little scary when you go to turn across traffic !!
There seems to be no pattern to it ? The other day it did it on and off for an hour in city traffic after a long drive (2.5 hours) then just once in the next few days of varied driving ? !!
Would my best start point be the "paperclip" test ?
Any help or advice would be very helpful  :)
Cheers
Rob
If its rusty cut it out.
If its dry, oil it.
If its dull, shine it.
If its stuck.......smack it with a hammer of course !!
hotel21
  • The Kingdom of Fife
Re: Intermittent Stalling ? ?
« Reply #1 on: 09 May 2011, 23:08:39 »
Check out the idle air control valve in the first instance.  Know there is one on the prefacelift v6's, think also one on the 2 litre desmonds...
Have a look at the maintenance guides.  Sure it will be covered in there....   :y
    • 530D M Sport, 330i Coupe
« Reply #2 on: 09 May 2011, 23:09:36 »
Get the codes read  :y
On a 2.0 could be 0340 - Cam Sensor.
« Last Edit: 09 May 2011, 23:10:17 by VXL_V6 »
hotel21
DeRangeRC
« Reply #4 on: 09 May 2011, 23:18:05 »
Wow thanks that was quick ! (insert joke here  ::))
Will try all of the above........
Many thanks
Rob
If its dry, oil it.
DeRangeRC
« Reply #5 on: 16 May 2011, 14:37:39 »
Ok so had another spat today of intemittent stall....  :(
Had driven half hour, stopped twenty minutes, then short trip home through town and it stalled five times in 5 minutes (pretty much every time I slowed past 5 MPH)
Came home printed paperclip test and nothing  :-? put in clip, turned ignition to II but nowt, checked clip tried with it at III, nothing.....
Am I doing something wrong or is the clip test not completely universal ?
Wanted to check codes before I tried to clean the IACV and to rule out Cam Sensor (had cam belt done 2000 miles ago).
Hmmmm an ideas.
If its dry, oil it.
Shelby
  • Sleaford, Lincolnshire
« Reply #6 on: 16 May 2011, 18:45:59 »
Check the small and large breather hoses plus the IACV.  I had the same problem with mine recently (also 2.0l 16v), was going to do it all as per the guide this weekend but forgot to pick up new gaskets for the IACV and throttle body.  Use the link H21 provided for info, thats exactly what I followed.
However, I did take of the small and large breather hoses, small one was quite clogged up with gunk and the large had a fairly good load in it as well.  I just cleaned them out with carb cleaner, then washed them out and let them dry.  To clean, I just bent the pipe in half (so it was U shaped) then effectively filled them up slowly with carb cleaner and let it do its magic.
Also, if you take the small pipe off, check the bit it attaches to on the cam cover.  That hole will probably be a bit clogged up also.  I used a small screw to clean mine, just gently screwed it into the caked on muck, then pulled it out, this brings all the muck out attached to the screw thread.  Make sure the screw is smaller than the hole so you are not actually threading into the sides of the pipe on the cam cover.
It is idling a bit better now.  If it is this, you probably won't get any fault codes, or at least I didn't.
Note: If you are going to do it, and it isn't that big a job in my opinion (I am not a mechanic  :P) make sure you get the IACV and/or throttle body gaskets.  The small hose is a right bitch to get off and back on with them in place.
« Last Edit: 16 May 2011, 18:49:10 by Tanthalas »
« Reply #7 on: 16 May 2011, 19:09:41 »
Forget the fault codes, its a gummed up throttle body, idle control valve and breathers;
Clean them out as per the guides and all will be good again.
« Reply #8 on: 16 May 2011, 19:10:54 »
The small hole for the small breather in the throttle body will be worse  :y
« Reply #9 on: 16 May 2011, 19:18:19 »
As MDTM says, this has all the symptoms of a dirty, sticky ICV and Throttle body, neither will thrown fault code...
Shelby
« Reply #10 on: 16 May 2011, 19:19:08 »
Yea, I need to do that but without the gaskets I just did a cursory clean of the bits I could get to.  Will probably be taking the throttle body etc all off this weekend to do it properly.
DeRangeRC
« Reply #11 on: 17 May 2011, 15:59:48 »
Thanks all, will get the gasket bought and get under the bonnet with me carb cleaner as soon as it stops precipitating for five minutes !!  ::)
Cheers  :y
Rob
If its dry, oil it.
Shelby
« Reply #12 on: 17 May 2011, 17:04:14 »
Cheers  :y
Rob
About £2 for the two gaskets from a Vauxhall Dealer, cheap as chips.
DeRangeRC
« Reply #13 on: 17 May 2011, 20:13:15 »
£2 thats a bargain, I might get two !  ;D
Oh and whilst we are on the subject.... would this problem make the temp hunt a bit ?
Drove about 25 mins tonight & hit traffic and the guage kept going up and down, nothing drastic & it didnt stall just going up a couple of marks then back down to around the 90 mark.
Is it linked or is this normal, never noticed it doing it before  :-/
Rob
If its dry, oil it.
« Reply #14 on: 17 May 2011, 21:16:20 »
temp sounds normal in traffic
