Author Topic: Throttle body cleaning  (Read 1597 times)
Stallion
  • Romford
    • 3.2 Irmscher Elite
« on: 20 May 2011, 11:26:49 »
Thought i give the throttle body a clean as iv got some free time on my hand, was worth opening it, as by the looks of it definitely hasnt been done in a while.
So the 2 black 90* hoses that connect to it, they seem to be wet inside, smelt and can confirm its petrol? is that normal??  :y
Tezray
Re: Throttle body cleaning
« Reply #1 on: 20 May 2011, 11:48:41 »
I think the 2 hoses that run to the throttle body are coolant hoses  :-?
The fuel lines run directly to the fuel rails that feed the injectors.
Stallion
  • Romford
« Reply #2 on: 20 May 2011, 11:50:07 »
thanks tezray, meant the 2 big noticable ones?
Tezray
« Reply #3 on: 20 May 2011, 12:18:42 »
Do you mean the air intake pipes? The one's the light blue arrows are pointing to here in the first picture?
http://www.omegaowners.com/forum/YaBB.pl?num=1285583252
If so, they shouldn't be wet or smell of fuel  :o
Stallion
  • Romford
« Reply #4 on: 20 May 2011, 12:39:42 »
yep those are the ones? i was thinking along those lines too, but aintgot the faintest whatmight be causing that??  :(
Tezray
« Reply #5 on: 20 May 2011, 12:53:41 »
What sort of mpg are you getting? Have you calculated it? The only thing i can think of is if you have some petrol mixed in your oil and the smell is coming from the breathers  :question
I'm not familiar with the 3.2 engines tbh, hopefully someone else will be able to shed some more light on this.
Page created in 0.008 seconds with 16 queries.
