Author Topic: Paperclip test..  (Read 2210 times)
Andy1766
  • Poole Dorset
Paperclip test..
« on: 21 May 2011, 18:09:33 »
Hi I have just done the paperclip test on my car and the results are:- 12, 18 (there was a break 4-4), 19 (same thing break 4-5), 73,19 and 12.
Any help please? Thanks
Re: Paperclip test..
« Reply #1 on: 21 May 2011, 19:00:46 »
Don't understand what you mean by a "break 4-4" and "break 4-5"  :(
19 is usually a crank sensor issue .. but could be historic  .... do you actually have the MIL light on at the moment ??
There is a page for decoding the sequences in the how to .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1160152415
HTH
STMO123
« Reply #2 on: 21 May 2011, 19:03:01 »
HTH
You will also get a 19 if the engine isn't running.
« Reply #3 on: 21 May 2011, 19:06:14 »
HTH
Not normally... 31 if engine isn't running normally, 19 means the Crank Sensor is probably on it's way out ;)
STMO123
« Reply #4 on: 21 May 2011, 19:13:12 »
HTH
When I owned one of these prehistoric cars, I got a 19 with  engine off and didn't get it with engine running, so mine must have been a 'special'. ;D
Andy1766
  • Poole Dorset
« Reply #5 on: 21 May 2011, 19:21:39 »
After seeing the code numbers I did not know that there were 3 digit codes, the revised codes are as follows, 12,144,145,73,19 and 12. The engine was off during the test..
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #6 on: 21 May 2011, 19:36:46 »
144-Immobiliser No Signal
145-Immobiliser Wrong Signal
73 -Mass Air Flow Sensor Voltage Low
19 -Incorrect RPM Signal (usually crank sensor)
Andy1766
  • Poole Dorset
« Reply #7 on: 21 May 2011, 20:00:48 »
Ok thank you any ideas on how to if needed to rectify the problems?
fiend61
  • york
  • each to their own
« Reply #8 on: 21 May 2011, 20:05:17 »
is there anything wrong with your car ? i.e poor starting etc
if not the codes might be old stored codes, a decent code reader should be able to clear them, then see if any turn back up again, then start your diagnosis from there  ;)
« Reply #9 on: 21 May 2011, 20:06:49 »
but be prepared to replace your crank sensor.  ;)
Andy1766
  • Poole Dorset
« Reply #10 on: 21 May 2011, 20:13:18 »
The engine light comes on at times, and sometimes cuts out when hot. The car has not been used for a while.
fiend61
  • york
  • each to their own
« Reply #11 on: 21 May 2011, 20:17:38 »
as andy says
« Reply #12 on: 21 May 2011, 20:22:57 »
Sounds like classic Crank Sensor to me... I'd advise you to at least get a spare if you haven't got time to fit it as it may well give up completely at the most inconvenient time ::) ::) Like it did to one of the Admins in France :-X :-X
Andy1766
  • Poole Dorset
« Reply #13 on: 21 May 2011, 20:23:35 »
Ok thanks
« Reply #14 on: 21 May 2011, 20:26:02 »
Should add, in case you don't know, that genuine Vx Part is recommended and an alternative route for the wire as per the guide :y
