Author Topic: Code P0140  (Read 2153 times)
Pippin
  • Birmingham
    • Vauxhall Signum 1.9CDTi
Code P0140
« on: 21 May 2011, 21:53:52 »
Hi All, my eml light came on this morning on the way home from work, but didn't have a look till tonight as sleep was needed. Well its showing the usual P0304 cylinder 4 misfire detected and a new one the P0140.....any ideas what the P0140 is and what may cause it?
Any help or advise would be gratefully appreciated...
Phill
RoSPA Gold Advanced Driver
Trade Card Holder
Re: Code P0140
« Reply #1 on: 21 May 2011, 22:30:08 »
P0140 Oxygen sensor (O2S) 2, bank 1 - no activity detected
I believe this code is listed as one for the 2.0ltr Omega engine and relates to the sensor after the cat, and would point to either a wiring fault or fubared sensor but don't quote me on it!  ;D :y
« Last Edit: 21 May 2011, 22:31:27 by philrich1064 »
Pippin
  • Birmingham
Re: Code P0140
« Reply #2 on: 21 May 2011, 22:32:16 »
Would that be the same for the 2.2 then?
Trade Card Holder
Re: Code P0140
« Reply #3 on: 21 May 2011, 22:36:54 »
Here are the fault codes for the 2.2 (Z22XE Engine)
http://www.omegaowners.com/forum/YaBB.pl?num=1197277611
Pippin
  • Birmingham
Re: Code P0140
« Reply #4 on: 21 May 2011, 22:39:57 »
Thanks, probably a silly question, but what might cause that to show up? a faulty sensor or something else...
Trade Card Holder
Re: Code P0140
« Reply #5 on: 21 May 2011, 22:54:27 »
As said ^^  :y
Quote: "and would point to either a wiring fault or fubared sensor"
Pippin
  • Birmingham
Re: Code P0140
« Reply #6 on: 21 May 2011, 22:57:09 »
Is there an easy way to test the sensor or is it a case of change it to try? :y
Trade Card Holder
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Code P0140
« Reply #7 on: 21 May 2011, 23:00:03 »
you can check the wires visually any damaged or loose, if nothing then would have to buy an try... :y
Pippin
  • Birmingham
Re: Code P0140
« Reply #8 on: 21 May 2011, 23:01:31 »
Sound, i'll have a look at it when i've finished this set of nights... :y
Trade Card Holder
