Author Topic: Which antifreeze?  (Read 3239 times)
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Which antifreeze?
« on: 20 May 2011, 15:08:45 »
I'll be changing the coolant shortly.  Currently have the regular green stuff.  Is it worth changing to the new red type?
If so, does it matter if it mixes with the remnants of the old green stuff or do I need to flush more thoroughly?
I feel like a military academy. Bits of me keep passing out.
neilr
  • Barnet, Herts
Re: Which antifreeze?
« Reply #1 on: 20 May 2011, 15:19:13 »
Red stuff is longer lasting supposedly 5 yrs System should be flushed claer if swapping over.
« Reply #2 on: 20 May 2011, 15:39:48 »
Vx Red stuff is about the best, especially on TC :y
Make sure you give the system a good flush through ;)
Osprey
  • Redhill, Surrey
« Reply #3 on: 20 May 2011, 16:40:01 »
Fairy snuff - sounds like the red stuff then, TC thanks to ABS.
I'll be doing the cambelt & water pump at the same time so I can flush through the engine block while the pump is out, as well as through the rad.
Is it worth running up to temperature on plain water just to get into the matrix and other nooks and crannies or is that a bad idea for corrosion in a cast iron block?
51M0N
  • Hull
« Reply #4 on: 20 May 2011, 16:44:25 »
red only suitable after 1999
pre 1999 is the green one.
  • Online Online
« Reply #5 on: 20 May 2011, 16:45:20 »
If you don't the thermostat will still be shut & you won't be circulating clean water around the block. Nothing will rust up in the hour or so it'll take to do the job.  :y
« Reply #6 on: 20 May 2011, 16:47:07 »
The red is backwards compatible as long as you flush the system through ;) ;)
« Reply #7 on: 20 May 2011, 16:48:41 »
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #8 on: 21 May 2011, 15:00:07 »
You want to flush it with plain water a couple of times and run the car up to temperature each time, taking the car for a short run is a good idea. Keep flushing until you can`t smell any antifreeze in the water and then it`s safe to use the red antifreeze.
The red doesn`t mix with the green stuff and has been known to turn to gel when the two are mixed if the system hasn`t been flushed properly, which can lead to blockages.
If you google it you will find plenty of info.
« Reply #9 on: 21 May 2011, 15:04:58 »
Vx Red :y
Note, unlike some other reds, Vx Red  is compatible with older antifreeze, though makes sense to flush through :y For a few days before doing waterpump, I'd daily undo drain on rad, then top up with water.  Then when you do waterpump, you'll get most of the system empty. Then refill with 50:50 Red
Just because its 5yr, I would still urge changing every 2 :y
« Reply #10 on: 21 May 2011, 15:06:44 »
That reminds me, the entire tunnie fleet needs new coolant...
Osprey
  • Redhill, Surrey
« Reply #11 on: 21 May 2011, 15:38:39 »
Thanks for replies.  Vx red it is, and a few daily drains beforehand.   :y
denisaok
  • East London
« Reply #12 on: 21 May 2011, 15:47:48 »
is red only available from dealer
To ask a question and feel idiotic for a moment is better than not to ask and be idiotic for a life time.
Osprey
  • Redhill, Surrey
« Reply #13 on: 21 May 2011, 20:13:22 »
Vauxhall red antifreeze, as recommended by others above, is Vauxhall dealer only as far as I know.  Other red antifreeze is widely available e.g. Halfords at £22 for 5l.  But with Vauxhall at only £14 inc VAT trade club (£17 list) I guess we're better off using the real McCoy.
denisaok
  • East London
« Reply #14 on: 22 May 2011, 02:32:59 »
Thank you
