Author Topic: Higher Temp than normal  (Read 3629 times)
venom
  • South Moreton, Oxfordshire
« on: 20 May 2011, 23:37:13 »
I've changed my header tank with a brand new VX one & changed the old blue antifreeze with the new orange VX coolant, it has always been fine sitting at around 90/95 even when it's sitting on tick over even if it's left for a long time, but it now goes to the 100 mark for a while but then drops to between 95/100 & does creep back up but only when driving but not on tick over & I'm not losing any water it's just at where it should be.
I've re flushed it added more coolant instead of some water so must be 70/30 mix at the mo, any clues  :question :(
« Last Edit: 21 May 2011, 06:31:49 by VENOM »
Ken
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: Higher Temp than normal
« Reply #1 on: 20 May 2011, 23:44:28 »
Mines the same. Sits around 95 then climbs to 100 fan kicks in and drops to 95... Hope it's normal too, lol.
AKA - Mr Bracket
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #2 on: 21 May 2011, 00:12:38 »
Thats pretty much normal matey!  :y
blackviper90210
« Reply #3 on: 21 May 2011, 08:11:58 »
Fair enough, can stop watching the gauge as much and enjoy the drive  :) :) :) :)
AKA - Mr Bracket
venom
« Reply #4 on: 21 May 2011, 15:21:22 »
My only concern was that untill I changed the tank & coolant it never got above the the mark before the 100 at any time  :exclamation
Ken
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #5 on: 21 May 2011, 15:23:57 »
Air in the system ? Sounds abit like an airlock...
venom
« Reply #6 on: 21 May 2011, 15:31:23 »
Thats what I think but I've all I can think of & followed the guide on here, so dont know :question
Ken
« Reply #7 on: 21 May 2011, 21:43:58 »
I'd say airlock, as 100C is too high.
JasonH
« Reply #8 on: 21 May 2011, 22:47:50 »
It might do that if the aircon is off or not working. When the air con is active two great big fans on the front of the radiator run and they really help keep the car temperature stable.
I had one fan fail and the fluctuation in engine temperature became noticable.
Stallion
  • Romford
« Reply #9 on: 21 May 2011, 22:55:11 »
i advised normal, as mine does the same, sometimes it goes 95 comes down, sometimes touches 100 and comes down. if it was sticking on 100c then thats a worry??
venom
« Reply #10 on: 22 May 2011, 17:36:06 »
This is really starting to do my @#$%ing nut in been out in the car today & the only way to keep the temp down to 95 is to have to heating on HI in the cabin, then it drops down to around 95/97 but put it in low & after 10 mins it creeps back up, but we pulled in to the motorway services & I cracked open the header cap just to release some pressure but there was hardly any if any at all  >:( so if the system isn't being pressurised would it get hot or no heat ad could it be my old cap
« Last Edit: 22 May 2011, 18:56:17 by VENOM »
Ken
« Reply #11 on: 22 May 2011, 19:37:36 »
Only in very extreme circumstances should it get close to 100C on gauge.
Quoting any of the 'mine runs at 95C' is pointless without stating what the midpoint temp on gauge is, as that varies on Omegas ;)
« Reply #12 on: 22 May 2011, 19:38:22 »
Do you get near brackley, so we can see what the 2 temp sensors read?
venom
« Reply #13 on: 22 May 2011, 19:53:25 »
No but its just up the road so I can do cheers mate
Ken
Abiton
« Reply #14 on: 22 May 2011, 20:53:50 »
Try draining some of your 70:30 mix and topping up with just water.  Coolant isn't as good at heat transference as water, so you want the right mix.
I wonder if your water pump isn't pumping as well as it once did?  Do you know when it was last changed?
You say orange coolant was used.  I've only ever heard about recent Vx coolant being red/pink.  :-/
