Author Topic: Camshaft data?  (Read 1610 times)
paulg
  • Spalding
    • 04 3.2 manual MV6
Camshaft data?
« on: 25 May 2011, 21:32:21 »
Does anyone know of any websites or any info on v6 camshafts, i.e. lift & durations of standard cams?  :y
Re: Camshaft data?
« Reply #1 on: 25 May 2011, 21:59:35 »
The info is probably on here somewhere. Might take a bit of finding though. Its generally acknowleged that the cams from a 3.0 or 3.2 will give some more bhp (18iirc) when fitted to a 2.5/2.6 engine. I believe it also helps to fit the lower inlet divider from the larger engine at the same time. :y
Guess what I have got sitting on my bench looking for a new home ? ;) :D ;D ;D
paulg
  • Spalding
    • 04 3.2 manual MV6
Re: Camshaft data?
« Reply #2 on: 25 May 2011, 22:06:47 »
Looking at Piper's web site, they do cams with 10.5mm lift, which I know G cams have 10mm, but have no info on the rest.
Im building a fast road 3.0, but dont want to go too far, as its an everyday car, plus tows as well. The only thing I need now are cams, but want to keep a bit of low dow torque.
paulg
  • Spalding
    • 04 3.2 manual MV6
Re: Camshaft data?
« Reply #3 on: 25 May 2011, 22:38:37 »
Ive got 2 ported dividers allready, dont suppose you have any 3.0 standard pistons have you?
Re: Camshaft data?
« Reply #4 on: 25 May 2011, 22:47:21 »
Sadly not. ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Camshaft data?
« Reply #5 on: 25 May 2011, 23:46:19 »
not long done mine,useful gains at higher engine speeds but no noticeable difference at low speed,I swear that it sounds better too :y
other rides
Martin_1962
Re: Camshaft data?
« Reply #6 on: 25 May 2011, 23:47:46 »
Definate improvement with the 2.6 as well
Re: Camshaft data?
« Reply #7 on: 26 May 2011, 10:26:35 »
I believe Mark's DTM measured the cam profile a while back so the information is probably on here.
Uprated cams (beyond 3.0 cams into a 2.5/2.6) don't appear to be a popular modification so there's little experience of them here.
One thing that will help is to fit the 3.2 exhaust manifolds, as these are lighter and flow better.
Re: Camshaft data?
« Reply #8 on: 26 May 2011, 10:27:30 »
paulg
  • Spalding
    • 04 3.2 manual MV6
Re: Camshaft data?
« Reply #9 on: 26 May 2011, 11:26:58 »
Cheers for the info  :y. Got a few F & E cams lying about, but will be no good in my 3.0. afaik, them cams have only 9.2mm lift, so G & A seems to be the way to go, unless I fork out for Piper cams. I also have some ported 3.2 manifolds aswell, thanks to Albs! :)
Re: Camshaft data?
« Reply #10 on: 26 May 2011, 11:54:11 »
Looking at that plot the duration appears to be 240-250 degrees (depends how you measure it, of course, but...)
http://www.pipercams.co.uk/pipercams/www/product.php?pid=OPV6BP270A
Piper seem to offer two cams:
248 degrees with 9.53mm lift
256 degrees with 10.54mm lift
Little if any improvement for £336 although, of course, the profiles might be more aggressive on the open/close ramps.
Add to that the need for a set of 4 vernier pulleys to set them up properly. Not a cheap exercise.
They quote power band 2000-6500 RPM for the more aggressive cam. Hmm. Not far off what my seat-of-the-pants dyno says the standard 3.2 is doing. ;D Perhaps I'd say it's dropping off a little earlier than that.
Makes me wonder if it's worth it. :-/
..and whether porting of the head is required before you get any gains at all, of course. ;)
If there's any grumpiness at low RPM a heavy car like the Omega can ill afford it.
Re: Camshaft data?
« Reply #11 on: 26 May 2011, 12:07:13 »
Was it you who bought my 3.2 fanimolds then ?
paulg
  • Spalding
    • 04 3.2 manual MV6
Re: Camshaft data?
« Reply #12 on: 26 May 2011, 14:35:16 »
It was me that bought them, cheers Albs!
 Those piper cams do one set for 2.5 & another for 3.0. so would be looking at the 3.0 ones, but your'e right about the cost, Kevin. It would seem like you dont get many horses more for what it costs. The heads are ported, & also inlet & exhausts are all modified, so would suit a more aggressive cam profile.
Re: Camshaft data?
« Reply #13 on: 26 May 2011, 17:35:13 »
You got a bargain there. ;) ::)
