Author Topic: headlight out  (Read 1424 times)
ajn
  • cardiff
headlight out
« on: 26 May 2011, 15:54:06 »
Hello the drivers side headlight is out on my car. The light  went out so i changed the bulb when I changed the bulb the fuse blew so changed the fuse and bulb, now the headlight still dont go on  all other lights ie brakes sides reverse etc working every thing but the driver side headlight any ideas as im a taxi driver and need to sort it for friday night cheers ajn
Re: headlight out
« Reply #1 on: 26 May 2011, 16:03:47 »
Check the wiring to that side for damage
ajn
  • cardiff
Re: headlight out
« Reply #2 on: 26 May 2011, 16:28:50 »
I have noticed a nic in the yellow wire half way up but only seems to be in the plastic covering but also the yellow plastic has rolled back off the wire as it joins the connector but still seems stable ajn
Re: headlight out
« Reply #3 on: 26 May 2011, 17:03:43 »
But it could be shorting out ;) ;)
Get some tape over it and try again :y
ajn
  • cardiff
Re: headlight out
« Reply #4 on: 26 May 2011, 17:45:01 »
nope even with the wire completely covered with tape  also the the inside seems loose compaired to the other side ajn
Re: headlight out
« Reply #5 on: 26 May 2011, 17:51:10 »
That sounds like broken adjusters ;)
Afraid you'll have to check the wiring as that's most likely cause of fuse blowing. Of course, it may have just been a dodgy bulb but...
ajn
  • cardiff
Re: headlight out
« Reply #6 on: 26 May 2011, 18:47:59 »
my mate just put some test thing on it theres now live going into the yellow wire so just to get me out to work im just going to run a wire off the other light :-? thanks for the replys ajn
Re: headlight out
« Reply #7 on: 26 May 2011, 19:01:18 »
Was it fuse #31 that you checked :question
Re: headlight out
« Reply #8 on: 26 May 2011, 19:06:02 »
Of course there's not... You said the fuse had blown ::) ;)
