Author Topic: lpg on a v6  (Read 1436 times)
tango
  • brum
lpg on a v6
« on: 26 May 2011, 21:01:56 »
hi
i recently been having a few issues with the omega with it running very lumpy
after checking a few things the problem was found
it was the gas regulator fitted to the lpg system
apparently its been leaking and causing a missfire on random cylinders
i went to the guy who fitted the lpg and he told me it was a rubber seal in the regulator wich had given way and caused the leak
this is the second time this seal has gone and he says its probably due to the gas not being warmed up enough
now my question is to the guys who have had their v6 converted
i need to find out wich of the cars water pipe they have used to feed the regualtor
as mine is currently been fed from the pipe that goes to the front of the plenum  and its not getting hot enough
thanks in advance guys
Re: lpg on a v6
« Reply #1 on: 26 May 2011, 21:07:09 »
Yep... That's plumbed wrong as the flow through that pipe is minimal ::) ;) It was obviously fitted by someone who wanted to make it as easy as possible and gives me concerns for the rest of the installation :o
Anyway... The only way to guarantee a good flow is to take the feed from the "Helter Skelter" pipe from the coolant bridge to the HBV :y :y
tango
  • brum
Re: lpg on a v6
« Reply #2 on: 26 May 2011, 23:03:18 »
Thanks for the reply
Wich ones the helter skelter
Any pics would be appreciated thanks
tango
  • brum
Re: lpg on a v6
« Reply #3 on: 26 May 2011, 23:04:59 »
And sorry forgot to ask would you just cut that pipe and put a conection in series
Re: lpg on a v6
« Reply #4 on: 26 May 2011, 23:13:56 »
The pipe that feeds the HBV from the engine. You need to be sure your vaporiser will flow sufficiently to put it in series (before the HBV) but it should ;)
Have a look in the maintenance section, although it's a 4 pot guide it's the same principle :y
Re: lpg on a v6
« Reply #5 on: 26 May 2011, 23:40:44 »
 Coolant exits the engine via the coolant bridge pipe and goes to the single inlet side of the hbv. So locate the hbv at the back of the sngine and that curly shaped pipe. You'll need to remove the scuttle.
As standard its
Coolent bridge > single inlet side of hbv.
It needs to be
Coolant bridge > vaporiser > single inlet side of hbv.
Hth
tango
  • brum
Re: lpg on a v6
« Reply #6 on: 26 May 2011, 23:51:16 »
Thanks for the replies guys
I'll go to the gas installer tomorrow and get it replumbed
hopefully it should cure the problem
Re: lpg on a v6
« Reply #7 on: 27 May 2011, 06:36:27 »
As standard its
It needs to be
Hth
As long as it not one of the few vaporisers that have a very low flow rate ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: lpg on a v6
« Reply #8 on: 27 May 2011, 09:31:06 »
If he did the job and breaked it up,  make sure you don't have to pay for it  :y
Might be worth finding out at what temp it switches over.
What system is fitted to your car ?
