Author Topic: transmission fault code  (Read 1202 times)
tangocat
  • Newcastle Upon Tyne
« on: 26 May 2011, 20:41:17 »
hi while i was clearing some fault codes i found one for the transmission any idea what p1740 is? It has not came back just curious
Re: transmission fault code
« Reply #1 on: 26 May 2011, 21:32:53 »
Was that from engine ecu, or gearbox ecu?
tangocat
« Reply #2 on: 27 May 2011, 08:54:29 »
Hi I got the code when i went to the gearbox section if that helps
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 27 May 2011, 11:23:38 »
Could be nothing 2.2 often throws up some daft codes when other systems are unhappy (CAM sensor per example).
What reader did you use for the codes :question
P.A. Caron de Beaumarchais
« Reply #4 on: 27 May 2011, 14:16:07 »
Did you actually read the GS8211 ECU, or is this some crappy reader that claims to do more, but actually just does Engine ECU?
tangocat
« Reply #5 on: 27 May 2011, 18:12:51 »
I used "My Naff Code Reader" and think it read the gear box ecu heres a load of stuff if it makes more sence
vehicleManufacturerECUHardwareNumber 96024111
systemSupplierECUSoftwareNumber: HZ 35 14
systemNameOrEngineType:  GS821 Z22XE
CalibrationDate: 01
Identifier: 0511
systemSupplierECUSoftwareVersionNumber: 0001
exhaustRegulationOrTypeApprovalNumber: Not programmed
VehicleManufacturerSpecific: 0260002716
VehicleManufacturerSpecific: 3337635596
VIN: W0L0VBM3511123434
RepairShopCodeOrTesterSerialNumber:  Not programmed
ProgrammingDate:  FFFFFFFF
systemSupplierECUHardwareNumber: BOS  0205000002
CalibrationEquipmentSoftwareNumber: 96024110 AR
« Reply #6 on: 27 May 2011, 21:51:35 »
I was half right, crappy code reader ;D.  But is from gearbox :y
