Author Topic: Cam gasket problem  (Read 1110 times)
henri
  • Vendee France near La Sable D'
Cam gasket problem
« on: 27 May 2011, 15:48:35 »
Need some help guys ,Started the strip down to replace gaskets got as far as taking the plenum off and had to stop have had an emergency come up so had to put everything back. Started the engine and the emissions light is staying on,not blinking,constant,have not driven anywhere yet so dont know if it will go off.What have I done wrong? :-[ :-[
Re: Cam gasket problem
« Reply #1 on: 27 May 2011, 16:34:18 »
My money is on you not reconnecting either
A - Front drive by wire connector
B - Rear multiram connector
Does it rev when you press the go pedal? If no, then A is your fault.
Otherwise it's probably B!
Less likely, are all the O rings seated, just thinking you may have introduced an airleak?
Cheers,
James
henri
« Reply #2 on: 28 May 2011, 13:32:37 »
Cheers,
James
Thanks for the advice James,checked the items you mentioned and all connected,loosed the torque bolts slightly and retightened ,left it overnight and the next day when I started the light went out as normal so fingers crossed the problems gone lol :y :y :y
« Reply #3 on: 29 May 2011, 07:49:54 »
Pedal trick for fault code.
« Last Edit: 29 May 2011, 07:50:48 by chrisgixer »
