Author Topic: Fuel left?  (Read 3717 times)
hoj
  • BURY
Fuel left?
« on: 27 May 2011, 01:28:06 »
When putting the display onto "range" and the reading reaches zero how far have you gone before the car runs out? (if anyone has actually tried that which i doubt)
Just trying to establish how much fuel is actually left in the tank as either my reading is wrong or the fuel is dissapearing somewhere.
3.2 Elite in Oyster
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Fuel left?
« Reply #1 on: 27 May 2011, 02:27:27 »
i have actually? since the moment it started range '0' i drove another 5miles. that being on dual carriageway = constant speed and it was a 2.2!  :y dont know how much more it wouldve gone though??
Re: Fuel left?
« Reply #2 on: 27 May 2011, 06:48:25 »
Got another 2 miles out of my old 2.5v6 until it conked out. So resigned myself to it being fairly accurate tbh.
Unlike a piece of crap Volvo  I drove once that ran out on the motorway with 20 miles range still showing.
Re: Fuel left?
« Reply #3 on: 27 May 2011, 06:50:03 »
I've hd the display down to 4 miles remaining. There was still over a gallon left though (brimmed the tank)  ;)
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: Fuel left?
« Reply #4 on: 27 May 2011, 07:12:35 »
I brim my tank when range gets down to about 30. Even then I've still got about 2.5 gallons left. I check the amount of fuel used and subtract it from 16.5.
TC and BnQ Trade holder.
sierrapaul
Re: Fuel left?
« Reply #5 on: 27 May 2011, 08:52:28 »
ive had 18 miles out my 3 litre elite with range flashing zero before it ran out :)
Steve Wood
Re: Fuel left?
« Reply #6 on: 27 May 2011, 09:11:02 »
I've filled mine when it's got to 30 miles and it took 59 ltrs, am I right in thinking the tank is 75 ltrs in total?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Fuel left?
« Reply #7 on: 27 May 2011, 10:09:59 »
The gauge reading can be abit dodgy
When mine reads just under the red, i've still get about 5 ltrs in there  ;)
The range ( if you have been driving pretty steady ) is pretty accurate
The pumps on these are "wet" pumps and wear out pretty quick if they don't sit in fuel all the time.
You also end up with lots of cr*p in your tanks that will clog up your filter  ;)
Re: Fuel left?
« Reply #8 on: 27 May 2011, 10:31:19 »
I've had about 1000 miles with the range flashing zero.
Doesn't burn much petrol since the LPG conversion. ;D
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: Fuel left?
« Reply #9 on: 27 May 2011, 12:19:36 »
 ;D ;D ;D :y
best wishes
Simon.
Re: Fuel left?
« Reply #10 on: 27 May 2011, 14:20:36 »
I once had 18m from when it first flashed 0, but I slowed from normal speed to 60mph, and clenched buttocks until the next services.
Generally, they are pretty accurate (if your driving style remains consistent - it uses the average mpg over previous few miles for calculation) going by my (regular  :-[) experiences, and the amount of fuel the car takes when that low
Stallion
  • Romford
Re: Fuel left?
« Reply #11 on: 27 May 2011, 17:25:01 »
So would this clarify you would roughly get about 10miles from the moment it shows '0' in range?
hoj
  • BURY
Re: Fuel left?
« Reply #12 on: 27 May 2011, 19:09:56 »
Mmmm interesting - i reckon my 2.5 does about 25mpg
However i recently put £10 in (which prompted me on this question) and the range went up to 29 so at £6 per gallon that doesnt add up.
I use the "range" option ALL the time and till now presumed it was quite accurate, better than the fuel guage which comes on when there is a gallon left and sometimes flashes when there is a gallon left i have never run out yet and dont really want to.
Quite often the range will NOT change when putting a £10 in even when resetting
3.2 Elite in Oyster
2woody
  • Northumberland
Re: Fuel left?
« Reply #13 on: 27 May 2011, 21:26:32 »
the fuel left is calculated from the lasat 200 miles of use, so it's possible to run out with the indicator saying 10 or so miles to empty, and it's also possible to run out with the indicator having said zero miles for quite some time
Re: Fuel left?
« Reply #14 on: 27 May 2011, 21:53:34 »
Think on Omega, its something like last 10 miles. Hence why immediately driving economically (stupid idea, I know ::)) pretty quickly affects range on Omega.
