Author Topic: Brake Pads  (Read 948 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
Brake Pads
« on: 29 May 2011, 20:09:14 »
Is there a maintenance guide for this? had a look could not find it :-?
Have only done pads on old cars, so not sure.
Re: Brake Pads
« Reply #1 on: 29 May 2011, 20:29:44 »
All easy enough. The bare bones are:
Fronts just undo the 2 calliper slide bolts 14mm?, whilst holding the pins with a 2nd spanner, 17mm?.
 lift calliper off, swap the pads over, and refit the calliper and retighten the bolts.
Rears calliper is fixed, pads a held in by 2 pins and a spring clip. Just drift the pins out, pull the pads,
rewind the pistons, refit pads, clip and pins.
Obviously missed a few steps, such as cleaning all the crap off the callipers, copper slip on the back of the pads etc.
HTH, Al :y
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
Re: Brake Pads
« Reply #2 on: 29 May 2011, 20:46:41 »
easy way to compress the cylinder piston back is with a G-Clamp, gently tightened - BUT you MUST undo bleed nipple otherwise the seal could be damaged...
Not so easy on the rears, but you can still use the G-Clamp to press the pistons back again with the bleed nipples open...
« Last Edit: 29 May 2011, 20:58:04 by Psychoca »
Omega 37
  • Northampton
Re: Brake Pads
« Reply #3 on: 29 May 2011, 23:30:58 »
ok thanks
I know how to bleed brakes etc so will give it a go  :y
