Author Topic: Loosing oil  (Read 1224 times)
Shelby
  • Sleaford, Lincolnshire
Loosing oil
« on: 31 May 2011, 12:17:49 »
Hi again,  as I slowly work my way through all the niggles and problems, I have another I could do with some hints / tips on where to look.
I seem to be loosing oil and therefore need to keep it topped up.
No obvious signs of leaks on the ground after being parked, although does appear to be a bit oily on the underside of the engine.
Hadn't noticed this before, but got stuck at 40mph behind a couple of trucks on the way to work this morning, upon hitting a short dual carriageway section I booted it a bit to get past them both and noticed a bit of a smokey exhaust during the hard acceleration.
Any thoughts on places to look, check for small leaks or signs of leakage?
cheers
Abiton
Re: Loosing oil
« Reply #1 on: 31 May 2011, 12:40:54 »
Quite likely to be valve stem seals, unless you have heavy external leakage somewhere.  Ours is starting to use quite a lot too, and I'm fairly sure it's this.
Just keep topping it up, the cat will burn most of it off fairly harmlessly most of the time.
Shelby
Re: Loosing oil
« Reply #2 on: 31 May 2011, 13:23:39 »
I assume no heavy leakage as I never get oil on the ground under the car even if stood for a couple of days.  Ill have to give it a closer inspection for any other signs of external leaks, but haven't seen any yet.
I take it the valve stem seals is a bit of a job then?  :P
« Last Edit: 31 May 2011, 13:24:09 by Tanthalas »
