Author Topic: Elite rear suspension problem  (Read 1809 times)
Nathan
  • Northwood
  • Just Getting Amongst It
« on: 31 May 2011, 14:55:07 »
The pump has packed up on mine and now i'm thinking
1, can i just replace the rear shocks with standard uprated items
2, someone advised to remove the pipe which connects to the shock on the passenger to lower the car by releasing the air left in the pump a little as it sits quite high now (pump issue ?) but i was worried it would lower the car too much as the pump is shot i would not be able to get it back up ????
 By the way its sitting at 715mm now  :(
Nathan
« Last Edit: 31 May 2011, 14:56:00 by natahn »
Irmscher Parts Wanted...........Vehicle detailing is my passion not just a hobby....
Varche
  • middle of Andalucia
    • Golf Estate
Re: Elite rear suspension problem
« Reply #1 on: 31 May 2011, 15:04:45 »
Why not buy a pump off a breaker on here. I have two you could have - both work fine. But postage would be from Spain.
They are easy enough to change, Three bolts and the wiring loom plus air pipe.
It would seem a shame not to stick with the rest of the system if it is just the pump.
You can use uprated shocks. I have a pair of Bilstein B4's on one car. It seems to work OK.
Nathan
  • Northwood
« Reply #2 on: 31 May 2011, 15:15:20 »
Thanks i will do either to be honest......
was worried about that pipe though
« Reply #3 on: 31 May 2011, 15:20:21 »
Got a known working pump here :)
Nathan
  • Northwood
« Reply #4 on: 31 May 2011, 15:24:53 »
Cheers Rob but i think i might just uprate the shocks and springs to be honest....
Do you know if i will have any problems if i take off that pipe on the rear shock ???
« Reply #5 on: 31 May 2011, 15:31:03 »
Not really sure Nathan. One way to find out I suppose :D
Nathan
  • Northwood
« Reply #6 on: 31 May 2011, 15:33:24 »
Like that  ;D
