Author Topic: security system hay wire  (Read 791 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
« on: 01 June 2011, 20:49:19 »
Hi guys need some advice ASAP,MIG is completely imobilised,cannot even lock the doors on the key they automaticly release,the radio switches itself on. Remote key does not work on any function >:(..
Today i opened a window slighty,but turned off the internal sensors with button on dash,then locked the car as normal,tonight unlocked as normal but i thought i had to press console button again,after that every thing went hay wire,car is now locked,door buttons pushed down manually,come out through rear passenger holding outside door up to lock :'(.. Any advise chaps im  LOST !
Cheers John
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: security system hay wire
« Reply #1 on: 02 June 2011, 00:19:15 »
Does the car start now?
If it were me then I'd disconnect the main battery, under the bonnet, for 1/2 hour or so see if that resets anything.
Be aware you may need to enter the code for the radio.
Also be prepared for a siren sound as you disconnect the battery leads, if you do get a noise then pop the lead back on, then turn on the ignition, then remove the key from the ignition. You now have around 15 seconds to remove the battery lead without activating the siren (powersounder).
