Author Topic: Thermostat link pipe  (Read 1485 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
« on: 29 May 2011, 19:02:16 »
Can anybody tell me the Vx part number for the seals please.
Doing the stat change on Thursday and will be sending SWTSMBO
for them. Avoids all confusion........ ::)
The happiest people don't have the best of everything,
they just make the best of everything they have.
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Thermostat link pipe
« Reply #1 on: 30 May 2011, 06:00:13 »
I only have the kat-code or similar, Opel-dealers use these numbers: 1338202 and you need two.
amba
  • Medway towns
    • German V6
« Reply #2 on: 30 May 2011, 09:50:13 »
NotBrackley, Northants
Gender:
Drives: 98 MV6, 03 Elite, 00 25, 89 ZX10
  Re: Replacing the thermostat
Reply #14 - 04. Dec 2010 at 10:39     Greeny18 wrote on 03. Dec 2010 at 22:55:
Does anyone know the part number for the coolant transfer pipe for a  V6 Omega
Need 2 seals at end as well (which you may have if you were planning on changing stat), though these vary with engine no.  The pipe itself is same across all V6s.
12 90411629 13 38 320 PIPE, THERMOSTAT HOUSING TO HOSE    1
 13 90410899 13 38 471 SEAL, RING  (E)
(E)  -08378122
      -14393646
13 9129999 13 38 202 SEAL, RING
(E) 08378123-
(E) 14393647-
2
I_want_an_Omega
« Reply #3 on: 30 May 2011, 21:48:21 »
Hope this goes ok. When Elite Pete & I did mine we had to sacrifice the pipe to get it off!  :(
Tonka.
    • 2000 2.5 CDX
« Reply #4 on: 31 May 2011, 21:21:14 »
According to Vx parts dept, the sealing rings will take two weeks to come from AMERICA  :o  :o
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #5 on: 31 May 2011, 21:25:41 »
I have two seals in the garage as my pipe came with them
Tonka.
    • 2000 2.5 CDX
« Reply #6 on: 31 May 2011, 21:33:36 »
Thanks Joff. I will return to Vx on Thursday and see if they can source one sooner. I don't want to get stuck without the pipe.  :-/
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #7 on: 31 May 2011, 21:41:34 »
As i did :-[ Now mine is a 3.2. Is the pipe the same if so
1.Transfer pipe seal X2 9129999 made in malta :-?
2.thermostat housing 90502201
3. housing seal 9128363
4.Transferpipe with two seals 90411629
hope this helps :y
« Last Edit: 31 May 2011, 21:59:24 by jonathan_davey »
Tonka.
    • 2000 2.5 CDX
« Reply #8 on: 02 June 2011, 15:14:10 »
As if by magic, the parts arrived at Vx yesterday................incredible  :-?
andyc
  • Norfolk
« Reply #9 on: 02 June 2011, 15:27:26 »
Thats rubbish. If anything they would come from Opel and at most would be 7-10 working days.
FYI Vauxhall's show over 120 in stock at Luton so somebody somewhere is pulling your chain.
I keep these in stock so a quick PM and you would of had them days agao :y
Andy
Thetford. Norfolk
