Author Topic: My car is a knocking shop  (Read 2135 times)
gazza57
  • Liverpool
« on: 25 May 2011, 17:03:29 »
 Hi, can anyone help,my car sounds terrible when driving over uneven road surface or bumps (knocking grinding sound),sometimes the steering wheel jerks to the left slightly,noise seems to be coming from the left.Anyone any ideas??
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: My car is a knocking shop
« Reply #1 on: 25 May 2011, 17:10:31 »
Lots of things it could be,wishbone bushes,balljoint,track rod end,drop links or even maybe the steering idler,you need to get it up in the air and check all joints and bushes
other rides
gazza57
  • Liverpool
« Reply #2 on: 25 May 2011, 18:26:37 »
Many thanks.
51M0N
  • Hull
« Reply #3 on: 25 May 2011, 18:29:05 »
Not what I was expecting.
I thought you was going to tell us it was regularly spotted at dogging areas.
« Reply #4 on: 25 May 2011, 19:32:06 »
Re: My car is a knocking shop - guess it pays to advertise  ;)
Seriously I would replace front drop links first - most probably the cause, cheap to buy and easy to fit!
If that doesn't cure it you've not lost a lot 8-)
gazza57
  • Liverpool
« Reply #5 on: 27 May 2011, 09:09:13 »
I've already replaced the drop link on the the left side as well as bushes and balljoint all to no avail,could it be the shocks or maybe the suspension strut as I'm feeling every bump on the left.Just to clarify this started as a slight knock several months ago and has increased in sound and ride conditions.
« Last Edit: 27 May 2011, 09:20:53 by gazza57 »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #6 on: 27 May 2011, 09:25:58 »
Has it got red interior "mood lighting "   ;D
gazza57
  • Liverpool
« Reply #7 on: 27 May 2011, 23:26:50 »
No mood lighting but plenty of oomph!!
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #8 on: 28 May 2011, 11:39:54 »
Are ........... decient suspention then  ;) ;D ;D ;D
51M0N
  • Hull
« Reply #9 on: 28 May 2011, 11:41:24 »
No wonder its knackered  8-)
erubus
  • blairgowrie
« Reply #10 on: 28 May 2011, 12:49:00 »
have you checked that there isn't a spring broken?  could also be a knackered top mount/top mount bearing.  either way both fairly easy jobs provided you have a decent road spring compressor.  The ones I have are things my dad made many years ago.  they slip off the springs quite regularly, goes off like a shotgun blast.  thankfully never had 3 lbs of steel in my face using them yet
gazza57
  • Liverpool
« Reply #11 on: 04 June 2011, 16:11:31 »
Thanks for all replies,my investigation will continue.
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #12 on: 04 June 2011, 21:12:19 »
holy sh#t for the sake of a tennner you risk that! op get it up in the air with a crow bar and check all the joints my mechanic also uses massive pipe wrench to press things down! to check for play! or try rocking the car up and down to see if you can get the same knocking noise while stationary it could be a knackered shock
« Last Edit: 04 June 2011, 21:19:08 by mrgreen »
Warning: Dates in Calendar are closer than they appear.
